Recommended intake system
Discussion in 'Performance and Tuning' started by ggalvan210, Oct 18, 2011.
  1. Oct 19, 2011 at 5:50 PM
    jandrews
    '09 FourDubDee TRD OR
    NOTHING is going to get your mileage back. That is the price for bigass tires. You can have either, not both.
    Performance increase is placebo effect.
    Let's be clear: NO intake alone is going to make a performance difference on these trucks. They primarily change the engine note to make it more pleasant.
    Snorkel will improve gas mileage, but not to where it was before you lifted and added tires. You also get the obvious water-fording advantages.
    Other than that, you have to move up to supercharger for performance increases. And that'll suck even more fuel - premium fuel at that.
  2. Oct 20, 2011 at 6:41 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you have "big-ass" tires and have lost some perf/mpg,,, a re-gear might be your best bet. Possibly consider some headers. An intake "might" get you 3-5hp at the top end of the rpm range,,, hardly noticeable, same appies to a catback if you are so inclined. You also might consider a MAF calibrator, especially if you're set on a Volant, but be aware that this only makes an improvement when in open loop (close to WOT, or cold engine, for the most part).
    There's not alot of NA improvements on this engine that are noticable gainers. An APR X-1 is not an option since you have an '11.
  3. Oct 20, 2011 at 2:21 PM
    ggalvan210
    ggalvan210 [OP] Member
    Goose
    Clarksville, TN
    2011 Tacoma TX Pro
    well thanks for the advice, not only was it helpful but it educated me as well. Im not gonna lie, I am new to this whole scence so im starting to pick up things as I go.
  4. Oct 20, 2011 at 2:25 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    stock box with a decent filter, (K&N, TRD, AFE-dry)
  5. Oct 20, 2011 at 2:28 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Side note, since my OBD reader came in i've been monitoring my S/c'd Fuel Consumption, not sure how calibrated it is but its reading about 23.5 MPG's
  6. Oct 23, 2011 at 6:47 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    If we are talking about the 1GR-FE 4.0L V6, then that statement is completely in error.
    On many engines these days there is little or no increase in power when an aftermarket air intake is installed, but that is not the case on the 1GR.
    When URD got our 2005 Tacoma, I immediately started looking for the "FREE" hp mods that I found for the older 3.4L V6. All of that is detailed on my website www.GadgetOnline.com.
    I got on the dyno and started running tests and tested it without the big main tube installed. No gain in power. Tested it with the lid off of the air filter box. No gain in power. Tested it with the carbon trap removed. No gain in power. Tested it with the lid off, the main filter out and the carbon trap out, NO GAIN IN POWER.
    It was very clear that the stock air filter box its self had to go. It makes sense if you really look at the design of it. The air has to make several sharp turns in there before it gets into the engine. All these turns makes so much turbulence that Toyota had to install a flow straightener before the MAF to calm things down to get a clean reading. All this adds up to a significant flow restriction.
    This led to the development of the URD TCAI. On my 2005 XRunner it gained around 18 RWHP over the stock air filter box and the faster you drive it take advantage of the increased dynamic air pressure that builds up in front of the vehicle to force more air into the engine then would normally be pulled in for more power.
    The URD TCAI was intended to be a street performance intake and it is ideal for the XRunners. If you are an avid off roader and go through creeks and streams it is not the intake for you. For you guys we have the aFe Stage 2si intake.
    aFe used to make the intake system for TRD and it is a very good intake. I tested that on my 2006 4Runner with the 1GR and the gain was 12 RWHP over the stock air filter box and we keep a large stock of these intakes with the ProDryS synthetic filter on the self at URD.
    Those are the two intakes we recommend the most. There are some others we have gained experience with over the years and here are a few:
    Volant- Nice design overall but there is a significant design problem that makes the MAF read very high causing the engine to run very rich killing power. Generally most with the Volant will have a loss of power over stock due to the increase in the richness of the fuel mixture. URD has a special program for our MAF Cal to address this. On one customer' truck a dyno test showed a loss of 15 RWHP with the Volant and after a retune with the URD MAF Cal the gain was 30 RWHP (15 over the stock intake only after correction).
    AirAid- We have dyno tested this and there is no gain because they retain the stock air filter box and convert it to a hot air intake. They are basically just sticking a cone filter where the main air tube is and removing the filter media from inside the air filter box.
    There are others that are hot air intakes, your basic filter on a stick and they pull in hot engine compartment air. This is not good for making power in general.
    If I can help you with a URD or an aFe intake, let me know.
    G
  7. Oct 23, 2011 at 3:48 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ^^^^ This
    Having personally owned both the AFE stage 2ci and now a URDTCAI, I definitely notice a difference in both
  8. Oct 23, 2011 at 3:54 PM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    what did you do with your stock wheels of the tx?
  9. Oct 23, 2011 at 3:55 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ... are you asking me??? and what are you asking
  10. Oct 23, 2011 at 5:11 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I know right?? Good, I thought my brain snapped and it was just me
  11. Nov 2, 2011 at 4:47 PM
    ggalvan210
    Goose
    Clarksville, TN
    2011 Tacoma TX Pro
    I have them stored away. why do you ask if you dont mind me asking?
  12. Nov 2, 2011 at 5:00 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    AFE Pro Dry Filter
  13. Nov 2, 2011 at 5:26 PM
    Captarm
    Captarm Well-Known Member
    Armand
    Maine and Rhode Island
    2010 SR5 Silver/Black, Tinted windows
    Leather Arm Rest Firestone Ride-rite K&N oil air Filter Wet Okole Black/Gray w heated seats Alpine CDE-123 receiver w Blue tooth,MP3,USB port AP Rock-sliders Viper Auto starter, should have gotten with alarm Anytime Fogs NOKYA7626 yellow lights Muth Heated, Signal Mirror Leer Cap Silver stream line top Differential Breather Mod
    auto anything
  14. Dec 4, 2011 at 9:04 PM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    I will dissagree with you, with the right setup you can feel power difference and you will really notice it if you are stressing your motor under a heavy tow, and when my foot is out of it with factory tires im get average 1.6mpg better.
  15. Dec 4, 2011 at 9:09 PM
    #35
    TacomaG26
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    r
    you could always change your gearing to get better MPG :D and change gearing on transmission to get more power;)
  16. Dec 5, 2011 at 6:31 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct. Without a tune it does run more rich. Due to the design of the system, and the diameter of the tube at the MAF sensor. It really wasn't well known what effects the Volant intake was having though, until the X-1 came out. With the ability to datalog the different sensors and comparing those with similar vehicles that had different intakes, the "issue" was quickly spotted. Thus a little fine tuning with the x-1 and bam. Problem solved.
    So for TacomaG26, if you have an EMS you can tune, and a wide band gauge or datalog device as well, you can make the Volant perform even better.
    Volant compared to stock, equal to less. Volant to AFe, AFe is better. Volant to AFe with a tune, equal.
  17. Dec 5, 2011 at 6:40 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Quoted for excellency in facts based off of testing.
    Others personal opinions are usually lacking due to strictly being an opinion based off of misinformation. Not all things are equal on all platforms and thus cannot apply universally.
  18. Dec 5, 2011 at 12:54 PM
    #38
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Thank You
  19. Dec 5, 2011 at 1:23 PM
    #39
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I had a k&n before and then got the AFE and noticed the difference right away. The thing that I like about the volant is the scoop however there is a mood you can do to the AFE or first gen TRD. http://www.xr-underground.com/forum/showthread.php?t=18400
    I guess we can call it coupes mod.
  20. Dec 5, 2011 at 1:33 PM
    #40
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    And I still have doubts about Ass dyno's not being valid, I drive over 100km's per day minimum, sometimes over 1000km's, if something in my baby changes, your damn right I'll notice
