Recovery Mod Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hafjell, Jan 9, 2023.
  1. Jan 9, 2023 at 3:06 PM
    hafjell
    hafjell [OP] Well-Known Member
    Idaho
    2023 TRD OR MT
    Sorry if this has been covered. Getting lots of conflicting advice.
    I do not want to spend a lot of money or change the look of the truck unnecessarily. I'm looking for simple and stealth recovery points.
    Do these seem like the simplest options that are still reliable?
    Rear from the trailer hitch. I would cover the hitch and stow the D-ring under the back seats until needed.
    Front ARB It's red so you know it's good.
    Am I missing any obvious options? Would these allow me to rescue and be rescued with something like this ARB dynamic recovery strap?
    TacoHungry and Bishop84 like this.
  2. Jan 9, 2023 at 3:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Just need another d ring to pair with the rope and you’re good.
    I’d start with a standard recovery strap not kinetic. 3” or 4” rated for around 30,000lb + I like smittybilt yellow.
    Kolter45, ToyoTaco25 and hafjell[OP] like this.
  3. Jan 9, 2023 at 3:25 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    ‘Yes you will be good for beach, fire roads and camp trails.
  4. Jan 9, 2023 at 3:30 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I also like to use soft shackles when possible. They float and if something leads to them flying thru the air I like them better than bow shackles.
    Good to have both if possible.
    helix66, RIX TUX, GarlicFarts and 6 others like this.
  5. Jan 9, 2023 at 3:30 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Learn a lot about recoveries and how to properly recover before buying anything. There are a lot of YouTube videos and every overland and off-roading rally I’ve been to has held recovery classes. Take them. Improper recoveries can kill someone and destroy vehicles very quickly. Just happened a few months ago where someone was improperly using recovery gear and a guy was unfortunately killed due to negligence. Once you know how to properly use the equipment, then buy what you want/need. Recovery points, soft shackles, “D” rings, kinetic rope, tow straps, chains, receiver shackles, winches, snatch blocks, energy absorbing blankets, synthetic rope, cable, traction boards, gloves…the list goes on of gear to choose from. Please educate yourself and then purchase.
    Dawelda, Kolter45, styk and 15 others like this.
  6. Jan 9, 2023 at 4:49 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    +1.
    https://www.youtube.com/watch?v=Mb3BkeeXlIo
    https://www.youtube.com/watch?v=2rHvQykNt2M
    i keep some soft shackles and a kinetic rope in the truck, the other car has a standard tow strap in it. neither is wrong, but the biggest mistake i and others have made in the past is to best understand the limitations of the gear. backing up and 'getting a better run at it' is the absolute worst possible scenario.
  7. Jan 9, 2023 at 6:50 PM
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    I was about to strongly disagree. But it seems that recommendation is nylon, so it's kinetic and won't likely kill anyone
  8. Jan 9, 2023 at 6:57 PM
    soundman98
    NW Indiana
    i'm curious to hear your reasons for a standard strap over a kinetic strap. strap load simplicity?
  9. Jan 9, 2023 at 7:11 PM
    Bishop84
    Yes, keep it simple, no furious recoveries, just simple pulls.
    Just for starting. Most of the time you just need a heavy strap to pull. I've only really offroaded maybe 15-20 times in my life, but I've only need a kinetic strap for mud once. Most of the other times were standard straight forward pulls with winches and straps.
    I always associate the stretch recovery to mud and sand, we don't have a lot of it up here and I assume most starters should avoid both.
  10. Jan 9, 2023 at 8:00 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    As I wouldn’t really know the breaking points of any straps or other vehicle parts, I wouldn’t do any type of running start recoveries, kinetic straps or not…
  11. Jan 25, 2023 at 9:20 AM
    chinoxmk22
    chinoxmk22 Well-Known Member
    Mario
    2023 Tacoma
    Glad I stumbled upon this thread. Learned something new and new fear unlocked.
  12. Jan 25, 2023 at 9:24 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    My dad always told me with the bow shackles you hand tight then back it off a quarter turn. Less likely to break as it allows the shackle to flex like it’s supposed to. Not sure how true that is but I can confirm that I’ve never seen one break even when ripping stumps out of the ground with a 78 f150 ranger and a logging chain…
  13. Jan 25, 2023 at 9:44 AM
    hafjell
    Idaho
    2023 TRD OR MT
    Ha! Me too.
    Taco22trdor likes this.
  14. Jan 25, 2023 at 9:49 AM
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    I have one of those and only put it on when I'm off-roading or when someone needs help. I reading pulling (reversing) from the front is not good on the transmission but not 100% sure.
  15. Jan 25, 2023 at 10:14 AM
    hafjell
    Idaho
    2023 TRD OR MT
    Thanks for the confirmation and for the advice. Presumably the ARB recovery point still good for recovery of my vehicle.
    eurowner likes this.
  16. Jan 25, 2023 at 10:15 AM
    blackZEBRA
    California
    '23 TRD OR DCLB
    Yes but the truck already has factory hook (i think passenger side) and one tie down point (driver side) in the front already.
    Martian__ likes this.
  17. Jan 25, 2023 at 10:24 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    I would never yank on any recovery point honestly. But that’s just me. Kinetics scare the shit outta me
    majpooper and soundman98 like this.
  18. Jan 25, 2023 at 10:25 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Reverse pulling is not good on the ring and pinion. The gears are strongest going forward, weakest in reverse.
  19. Jan 25, 2023 at 10:33 AM
    DuffyBank
    DuffyBank Well-Known Member
    Doubtful in most recoveries that the shackle is the weak link. More often a weak recovery point on the vehicle or strap/rope.
    towing a vehicle, regular strap or chain, recovering a vehicle, dynamic strap/rope
    Gunshot-6A, hafjell[OP] and Martian__ like this.
  20. Jan 25, 2023 at 10:53 AM
    Martian__
    Martian__ Well-Known Member
    Southern California
    I came across this too when doing research. The weakest part of the recovery should be the strap so that I can break off without damaging the vehicles or possibly killing someone outside the vehicles.
    the Arb straps are good and give you enough “stretch” instead of the excessive kinetic ropes. You should also have some kind of dampener or weight bag in the middle of the strap just in case one end breaks off. ARB has great recovery videos when compared to Rhino USA stuff. Watch some videos of professional tow/recovery companies rip apart Rhino USA.
    You honestly don’t need more than the front stock recovery points. The manufacturer does tons more research and development on them vs other companies. Those stock points are more than enough and the trailer hitch adapter is also a great recovery point. Just get a good strap that’s backed back actual product testing and development and you’re good to go.
