Recovery Mod Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hafjell, Jan 9, 2023.
  1. Feb 8, 2023 at 2:44 PM
    #61
    Vegvisir Overland
    Vegvisir Overland Well-Known Member
    Central OK
    2020 Tacoma TRD Pro Army Green
    Took the bed mat from 2nd Gen to 3rd Gen
    Any particular reason? I've run the Curt shackle hitch on a few recoveries. The Factor 55 Hitchlink is rated for 9500lbs while the Curt shackle hitch is rated at 13000lbs.
    I'll add the Curt hitch is solid steel and very substantial. It is larger in length than any of the aluminum shackle hitches I've seen and the two pin holes for 90 degree mounting is offset from each other.
    ARCHIVE and BC Hunter like this.
  2. Feb 8, 2023 at 6:03 PM
    #62
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    While there is a very low chance of that metal shackle coming undone, I'd use a soft shackle instead.
    All bets are off if a metal shackle fails at the end of a kinetic rope.
    LeakyAC likes this.
  3. Feb 8, 2023 at 7:29 PM
    #63
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Get a kinetic rope and soft shackles....
    Unless you know what you r doing, stay away from metal shackles and metal winch cable
    faawrenchbndr likes this.
  4. Feb 8, 2023 at 8:25 PM
    #64
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    rainsux, Taco22trdor and GREENBIRD56 like this.
  5. Feb 9, 2023 at 3:33 AM
    #65
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    My job has me working with professional riggers and cranes several times a week. Every time I see a shackle get installed it is hand tightened until seated, then backed off, then retightened to verify it's just touched off on the seat. Every one of the riggers carries a spud wrench to loosen after lift if needed.
    I used to do a lot of off roading in my youth. Had an 82 Long bed sitting on 38" super swampers and we spent a lot of time in the mud. We came upon a mudhole on a trail one day and there was a group of guys and several vehicles blocking the way. They had just attempted a recovery on a 85 access cab SR5 that was stuck. They wrapped a chain around the center of the rear step and tow bumper, and then added a kinetic snatch strap to the chain with a shackle. They hooked it to a recovery point on the rear of a full size chevy truck. When the driver snatched the Toyota, the bumper snapped right in half, shackle and chain recoiled and went right thru the tailgate of the chevy and shattered the rear window right behind the driver. If the tailgate hadn't slowed the shackle down it probably would have killed the driver. I never looked at a recovery the same way after seeing that. Know your equipment, it's potential, it's weaknesses, and the proper uses for it. It may save your life some day.
  6. Feb 9, 2023 at 6:16 AM
    #66
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    It might go without saying - but if you don't have a "commercial" line dampener in you kit - always have something to use instead. I have typically used an old canvas tarp (saw better days on the road and had plenty of wounds) to saddle the line. And numerous times we've used some soggy old Carhartt coveralls or jacket from an oilfield job ....... just don't risk nekked.
  7. Feb 9, 2023 at 8:43 AM
    #67
    Vegvisir Overland
    Central OK
    Ok, I thought you were referencing an issue with the Curt hitch specifically. I agree on the soft shackles, but I'm ok with using the 6.5 ton WLL shackle.
    BC Hunter likes this.
  8. Feb 13, 2023 at 12:30 PM
    #68
    hafjell
    hafjell [OP] Well-Known Member
    Idaho
    2023 TRD OR MT
    What am I looking at. The ARB recovery point painted black? Cool. So it sounds like you're a believer? Haven't pulled the trigger yet.
  9. Feb 13, 2023 at 12:52 PM
    #69
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Neither of which are rated for recovery.
    ARB recovery point if you don't have an aftermarket bumper with recovery points.
  10. Feb 13, 2023 at 12:55 PM
    #70
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    All black everything is slick and all until its pitch black out and u cant see sh*t lol
    rainsux, RIX TUX and BC Hunter like this.
  11. Feb 13, 2023 at 12:56 PM
    #71
    LeakyAC
    u def dont wanna get real stuck and have to execute any sort of dynamic type pull on those little hooks. They're held on by a couple small bolts onto a very light reinforced part of the (sub?) frame
    Theyre 100% fine for slow straight pulls...like onto a flatbed
  12. Feb 13, 2023 at 12:57 PM
    #72
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I
    I haven't read all the posts yet, but there is only one stock point on the front. The hook. The loop is NOT to be pulled from.
    Gunshot-6A and hafjell[OP] like this.
  13. Feb 13, 2023 at 12:57 PM
    #73
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    These trucks are body on frame. No sub frame lol
  14. Feb 13, 2023 at 1:09 PM
    #74
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    The stock tow-point isn't rated, though it can take a certain amt of pull. The driver-side loop isn't a pulling point, it's just there to use to tie down the vehicle during transport by cargo ship or on a road-bound car carrier trailer.
    Using the stock tow point for anything beyond mild, low-load, & probably NON-snatch recoveries risks either frame damage or tearing it off completely.
    The ARB recovery point is rated for 16,000 lbs max pull, from any pulling angle within the left/right turning angle of the front tires.
    The ARB costs $$$, but as far as I can tell there really aren't any other properly-engineered, fully tested, and rated recovery points for the front end of Tacomas. Here's more info & analysis I wrote on this subject, elsewhere.
    DarkestCon, hafjell[OP] and chuam like this.
  15. Feb 13, 2023 at 1:15 PM
    #75
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If I can't find that thing at night, I would be surprised, not even considering the headlamp and flashlights that are along.
    02Duck likes this.
  16. Feb 13, 2023 at 1:16 PM
    #76
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It connects to more spots, esp the main frame rail. A definite upgrade over the OR Tow Hook.
    hafjell[QUOTED][OP] likes this.
  17. Feb 13, 2023 at 3:31 PM
    #77
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Great info videos here - I am taking my nipple rings and tow hitch shackles off and stowing them so they don't rust even though I think they look "cool."
    The other thing is; I do have a recovery strap and I am going to get a couple of soft shackles but I am never going to try a kinetic recovery without someone who really knows what they are doing. I have only had to be recovered once (October 2017) in soft sand and they used a recovery strap not kinetic but also not soft shackles.
  18. Feb 13, 2023 at 3:49 PM
    #78
    GilbertOz
    GilbertOz Driver
    CA
    There's no comparison at all. The stock tow hook has no published load rating. It's an 8 or 10 ounce hunk of metal with 2 bolts on it.
    The ARB recovery point weighs 27 pounds and is fastened by lots of bolts in different frame locations & planes to stiffen it all up & make it worthy of a claimed (and no doubt tested by ARB) 16,000 lb pull.
    hafjell[OP] likes this.
  19. Feb 14, 2023 at 5:41 AM
    #79
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have used, and have seen folks use, both the left hoop and tow hook. For normal, easy recoveries. They work great and are equivalent. One is welded and the other is bolted. For bad recoveries such as mud, a connection to the main rails is needed.
    In the end, the biggest deal is a smooth pull. A recovery strap or kinetic rope is what is going to prevent damage.
  20. Feb 14, 2023 at 7:44 AM
    #80
    LeakyAC
    I know, but that rectangular tube running across the front end below the front bumper doesnt seem to be part of the actual frame itself, no?
    jerrybear and BC Hunter like this.
