Recovery Points
Discussion in '1st Gen. Tacomas (1995-2004)' started by Albinator, Apr 8, 2016.
  1. Apr 8, 2016 at 10:35 AM
    Albinator
    Albinator [OP] Well-Known Member
    Utah
    2000 Tacoma 2.7 Manual SR5 4x4; Manual Hub
    Where is the rear recovery points on my 2000 Tacoma 4x4? I took a picture where I think they may be. Can you guys point them out to me?
  2. Apr 8, 2016 at 11:49 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    There are none from the factory. You have to add them.
  3. Apr 8, 2016 at 12:33 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    A d ring through the hitch hole in your stock bumper (probably will bend the frame plates at some point). Aftermarket like TG bumper or add a 2" receiver and toss in one of those nice hooks.
  4. Apr 8, 2016 at 2:14 PM
    Albinator
    Utah
    Good thing I asked before I tried at some point...can you direct me to a good set that is wallet friendly and where it installs? Yeah would rather not attach eo the stock bumper. I've got a ball hitch connected onto it anyway.
  5. Apr 8, 2016 at 3:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  6. Apr 8, 2016 at 3:23 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  7. Apr 8, 2016 at 8:54 PM
    Albinator
    Utah
  8. Apr 9, 2016 at 5:31 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    A new hitch is half the cost of a TG bumper not really worth buying a hitch unless you get one from Craigslist or a place like LKQ.
  9. Apr 9, 2016 at 10:03 AM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Apr 9, 2016 at 11:40 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I have a Reese tow hitch that attaches to the frame that is still sitting with my stock bumper that I put away after I installed my new TG rear bumper. Too bad I live in California. @Albinator
  11. Apr 9, 2016 at 11:41 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    IEsurfer likes this.
  12. Jul 21, 2016 at 9:17 PM
    Albinator
    Utah
    Could I at a hook to the rear frame somewhere (or d-ring) like it is with the front passenger hook?
  13. Jul 21, 2016 at 9:44 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    Surprised nobodys mentioned this but the rear of your frame looks pretty rusty. You could box it in and weld another crossmember just behind the bumper and have a hook on it.
  14. Jul 21, 2016 at 11:59 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It all comes down to if your extracting someone or extracting yourself.
    Pulling others a receiver hitch works best .
    Then getting your vehicle out when the rear bumper is close to ground level slings around the rear axle work well protecting them from being cut with padding
    Then if the OP could fabricate most likely no need to ask.
  15. Jul 22, 2016 at 12:10 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Im not nure why there isnt a factory hook on it. My 2002 came with one. Check for 2 bolt holes about 2 in apart in the bottom of the frame, drivers side.
    Edit: nm. Looking at the picture in your first post, they would be just below where you thought a recovery point should be.
  16. Jul 22, 2016 at 8:55 AM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    It depends how much force is gonna be pulled. These 1st gen rear bumpers are pretty stout, if there aint that much weight, you could just wrap a strap around it twice. Personally I'd get a hitch with a ball off craigslist.
  17. Jul 22, 2016 at 9:00 AM
    devinzz1
    devin
    95 extended cab sr5
    I broke my mount off tugging a s-10 out of the woods.
  18. Jul 22, 2016 at 9:02 AM
    mhorton1911
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Thats why I said it depends on the load, we do this the pull dead tractors and trucks on the ram charger we have at the ranch with no problems
  19. Jul 22, 2016 at 8:10 PM
    Albinator
    Utah
    My bumper has the stock ball but I've heard not to use it to pull/recover others
  20. Jul 23, 2016 at 9:21 PM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    The balls have been known to fail. They break, and now you have a metal hitch ball being shot at you from a 30 foot long slingshot. Deadly to say the least.
