Recovery points?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2flyfletchguy, Jan 17, 2021.
  1. Jan 17, 2021 at 7:23 PM
    eurowner
    eurowner Duke Sky
    Scoty
  2. Jan 17, 2021 at 7:24 PM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Jan 17, 2021 at 7:27 PM
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    averagejp likes this.
  4. Jan 17, 2021 at 7:58 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    From my research the ARB one is pretty much it. The rest don’t attach to the actual frame on multiple points like the ARB is designed. I wouldn’t trust the tow points on my truck as has been mentioned. As far as I can find Toyota determines these to be tie down points for shipping not to be seriously used for any recover.
  5. Jan 17, 2021 at 7:59 PM
    MadKatt
    Looked at that one it has the same problem as the other daemon bracket it does not bolt down to the actual frame at multiple points which is needed for a real recovery point or so my research says.
    averagejp and e_engstro[QUOTED] like this.
  6. Jan 17, 2021 at 8:06 PM
    e_engstro
    Eric
    Arizona
    Gotcha, good to know thank you.
  7. Jan 17, 2021 at 8:16 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    I researched the dickens out of recovery points. Honestly, I think I looked at every single option out there. Clearly the ARB one is the best -- as it bolts to the frame of the truck. I get that it is expensive but it is rated, bolts to the frame and seems like the best option on the market bar none. I decided that I was not going to buy it because it is probably overkill for what I need (I am pulling people out of the snow and doing what I call very light recovery). I am not a hard core overlander (by the way, nothing wrong with that) but I don't think I need it. Also, after reading the install instructions (there are some excellent posts here!) I figured it was beyond my skill set. :).
    For my use, which I call light to moderate off roading, the one from BP will suit my purposes. It is rated. And while it connects to the bar across the front -- and not the frame -- it does have three bolts. Nice people, too. My understanding is they are also working on one for the driver's side and if they have that available I will get that one too.
    I also plan on getting this for rear recovery:
    https://www.rhinousainc.com/collections/recovery-gear/products/shackle-hitch-receiver
    So my strategy will be use that in the back and the one from BP in the front and I should be good to go.
    But then again, my use is expected to be 1 to maybe 5 on the recovery scale. More like towing and doing very light pulling from people stuck on the side of the road in a snow bank type of thing. If my needs were more rugged, I would definitely get the ARB.
    Just wanted to share my strategy as it related to my intended use.
    MadKatt likes this.
  8. Jan 17, 2021 at 8:24 PM
    MadKatt
    Totally understand I’m roughly in the same boat but there are times being out in nowhere when I need the confidence of a strong recovery point. Since I won’t be getting a winch or a beefy front bumper I can really only find one other solution which is the ARB one. You will probably be fine with what your going to do since there is a long track record of others doing similar things with no issues.
    averagejp[QUOTED] likes this.
  9. Jan 17, 2021 at 8:31 PM
    averagejp
    Work in progress
    100% agree. I am in the Northeast. We have some good trails and stuff -- especially when I head up to Northern Quebec -- to be with family but that's not really the kind of hard core off roading that is in the West, for sure. I've pulled a ton of people out of snow. But I wouldn't call that "recovery" per se. I think I will be fine. But if my life depended on it, and I was doing hardcore off road, I would not hesitate to get the ARB. I think I read it was the only one that is rated if you are doing recovery at an angle -- which is probably what most people are doing.
    By the way, I came across these in my research. Of course, not available here or for Tacomas from what I can tell. Wish they were since this looks like a good option:
    https://www.the4wdshed.com/recovery-tow-point-shackles-equaliser-strap-kit-toyota-fj-cruiser
  10. Jan 18, 2021 at 4:53 AM
    Loco_Driver
    Loco_Driver Well-Known Member
    Connellsville, PA
    2018 TRD OR DCSB M/T
    Loco Driving Mode
    MadKatt and Pat3002t like this.
  11. Jan 18, 2021 at 5:56 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    The Tacoma doesn't have any OEM recovery points.
  12. Jan 18, 2021 at 6:46 AM
    Bertlow
    Bertlow Well-Known Member
    Alberto
    Tocoma
    My experience for what it’s worth.I got the Arb bull bumper so the stock recovery point does not work so I bought a cheap hook to put there and that was a mistake bent that part of the frame win I hit a rock needle to say I got the ARB point and it’s built like a brick shit house love it
  13. Jan 19, 2021 at 8:41 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Those are far from the safest option.
    And you should never, ever, yank on chains. Just google tow chains breaking and you'll see videos of people loosing their lives with a chain to the face.
    You'll notice that tow truck drivers always use those with a winch, they're never yanking their buddy out of the mud with those chains/hooks with a dynamic load.
    A much better option is a front hitch with a D-ring in the receiver. They even make ones with recovery points on them, too (for some makes/models). They distribute the load to both sides of the frame.
    Even the ARB recovery point only attaches to one side of the frame.
    Doc62 likes this.
  14. Jan 19, 2021 at 8:43 AM
    jbrandt
    Justin
    Is there supposed to be a statement here?
  15. Jan 19, 2021 at 8:50 AM
    #35
    tractorfarmer123
    tractorfarmer123 Well-Known Member
    2020 Tacoma
    Yes, the Curt front hitch is only $160, but you need to notch the plastic bumper to get it to fit on the higher up models. On the low models you just take off the air dam. It attaches with 2 bolts on each side.
  16. Jan 19, 2021 at 9:32 AM
    #36
    Loco_Driver
    Connellsville, PA
    Loco Driving Mode
    TLDR:
    If you want an inexpensive way to successfully recover a vehicle you can buy a towing V bridle for not that much and be assured to pull your rig our from any direction with a good recv. If you connect to a substantial part of the frame yourself, then you can be guaranteed no damage as long as the hook is safely connected(takes experience). ARB offers a front connection, but that won't always work. If you use a normal strap, that metal hook at the end is just as dangerous as a chain. So know the limits of the equipment you're using! If you're doubting yourself, then open the hood to protect yourself from any flying metal. This is all on my experience. When I was younger I broke through a grill with a strap breaking throwing the hook , and I've bent class III hitch components trying to unbury my plow truck . You don't learn all this stuff from sitting around. So whoever is reading this, and not familiar with recovering a vehicle, do your homework so you don't damage anything or hurt yourself. Start small, and look to wise elders to teach you!
    It all depends on the situation. If you have a truck that is extremely buried, then yes, I would use some R hooks(or whatever is best) on a V bridle, hooked to a kinetic rope, and some common sense. No you shouldn't have an inexperienced person yanking on chains. I've been around the block a few times, pulling multiple rigs out from in the Rockies, and hot air balloon rigs with a hot air balloon aviation setup in an enclosed trailer(about 4,000 lbs) from its frame back to its wheels in sand without disconnecting the trailer. If you want the least amount of damage, and you have something really stuck, a one point hitch connection isn't always the safest. If you want an example of how to do countless recoveries quickly, go youtube matt's off road recovery and observe some recoveries. Then look at other examples around the country on youtube and learn how to do it. There are lots of different situations that can limit you such as sand, mud, ice, snow, water, being high centered, gravity, missing a wheel, etc... You have to use experience and common sense. Yanking something out solely by its hitch isn't meant for that force. Now if you are installing it yourself for that reason you can see how it's connected and assure it won't damage anything. The safest connection is to use a shackle that is meant for the load you are tugging, but you can't always shackle up to something in the way you need to without using towing hooks...
  17. Jan 19, 2021 at 10:27 AM
    #37
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Add me to the "plans on getting the ARB recovery point" list.
    poopshute likes this.
  18. Jan 19, 2021 at 12:10 PM
    #38
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    This, this, and this. If you want a true recovery point, the one ARB provides is your best bet. The stock hooks are mainly used for tie-downs and some light pulling. They are only held on by a couple of bolts and any hard, repeated, tugs may eventually cause them to fail. The ARB versions have been fully tested (at all angles) for recovery. If you've noticed, ARB does not install recovery points on their bumpers because they state that this can cause issues with the air bags. They actually recommend these recovery points even if you buy one of their bumpers.
    If there is a group buy, I'm totally down!
  19. Jan 19, 2021 at 12:50 PM
    #39
    PThy
    PThy Well-Known Member
    Pat
    SoCal
    2020 TRDOR MT
    Same here
  20. Jan 25, 2021 at 9:33 AM
    #40
    2flyfletchguy
    2flyfletchguy [OP] Well-Known Member
    Nathan
    2017 tacoma trd off road
