Recovery Q&A and help.
Discussion in 'Recovery' started by 3378jakesr5, Jan 5, 2017.
  1. Dec 14, 2020 at 5:41 PM
    #161
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Front: Buy a bolt-on recovery point, for example BPF or Demon. You'll need to cut a hole in the plastic airdam if you still have it on. The welded hoop is OK for a light recovery depending on how stuck you are. J-hooks or soft shackles around the lower control arms with a bridle also work, but you'd be limited in steering angle.
    Rear: Remove the plastic cap at the center of the bumper step. It should reveal a hole in the bumper crossmember, which is tied to the frame. Run a soft shackle through that hole:
    Alternative is a soft shackle around the rear axle, but you need to be very careful not to crush the brake line or ABS wire.
  2. Dec 14, 2020 at 5:55 PM
    #162
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    That is a very bad idea.
    You should always attach to the vehicle's frame, never to any suspension components. Suspension components, while strong in their designed load, are not designed to be pulled on. You can and will separate them from the vehicle.
    Always use an anchor point on the frame.
  3. Dec 14, 2020 at 6:01 PM
    #163
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The main suspension points (lower control arms, solid axle) are designed to take the weight of the vehicle in multiple directions. Imagine backing into a foot-tall ledge at slow speed. You can hang the whole truck from the rear axle. If you got a beefy anchor point on the frame, use it, but it isn't an always/never scenario.
  4. Dec 14, 2020 at 6:32 PM
    #164
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    Thanks.
  5. Dec 15, 2020 at 6:02 AM
    #165
    Scott B.
    Scott
    Georgia
    We can agree to disagree.
    Sure, you can hang your truck from your rear axle. But, that is a very different load than yanking on it pulling a truck out of mud while buried up to the frame.
    Not trying to start a fight - my experience says no.
    s.e.charles and Slashaar like this.
  6. Jun 20, 2021 at 9:46 AM
    #166
    s.e.charles
    s.e.charles Well-Known Member
    big spread in cost. is one better than the other?
  7. Jun 20, 2021 at 11:46 AM
    #167
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    What do you mean? The BPF bracket is $100 while the Demon bracket is $80. I like the Demon bracket design better because it uses interlocking plates and wraps around the crossmember, so it doesn't rely on the welds or bolts for strength.
    Note: do not get the Demon bling shackles. Those are machined out of aluminum and mostly for show. :)
    C41n likes this.
  8. Aug 8, 2021 at 1:16 PM
    #168
    s.e.charles
    i just meant one is 25% more than the other.
  9. Apr 23, 2022 at 8:58 AM
    #169
    cameron172
    cameron172 Well-Known Member
    VA
    2017 Super White TRD Sport MT
    Planning a solo trip to some trails…is there any point in bringing a hi-lift jack for a stock truck with no sliders, after market bumpers or jack points?
    I was thinking if there’s no good place to lift the truck from, then there’s really no point in buying a hi-lift and mounting brackets?
  10. Apr 23, 2022 at 1:29 PM
    #170
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    By itself? Not much. If you have a couple of tow straps it can be used to help winch yourself out. If you are new to recovery gear it's not the first thing I would acquire. I'd also figure out how to use it before you go out, they can be very dangerous.
    Slashaar likes this.
  11. Apr 25, 2022 at 1:25 PM
    #171
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    What kind of conditions are you expecting is #1 consideration.
  12. Aug 3, 2022 at 1:30 PM
    #172
    Bikeric
    Bikeric Well-Known Member
    Eric
    Tulsa, OK.
    1996 ExtCab 4x4 Wrecked Project
    Extra Crunchy Taco
    My radiator core support was so badly mangled in a wreck that a new AC condenser would not physically fit. I had to spread out the "crunch" and just using my winch wasn't going to work as it just pulled the truck across the ground. I made a double anchor using 2 of my longest, skinniest tools from my toolbox. I drove the first into the ground closet to the truck. I used a strap and walked out to the location for the 2nd anchor. I drove it in with minor tension on the strap. These anchors worked great and were really easy to remove when just pulling up. I will now be carrying these with me on my trips, and the big sledge hammer. The Pull-Pal looks great, but my wife would kill me if I tore up the yard.
  13. Oct 26, 2022 at 7:52 PM
    #173
    Cpl. Punishment
    Cpl. Punishment Young men never die.
    Neil
    Alberta, Canada
    2020 MGM Tundra SR5
  14. Sep 2, 2023 at 12:00 PM
    #174
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
  15. Oct 26, 2023 at 5:03 PM
    #175
    originalNAS
    originalNAS Active Member
    2018 Black TRD Off Road
    This was a great and important video! Glad he made it!
  16. Nov 20, 2023 at 11:30 PM
    #176
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Going to take advantage of the yankum BF sale and get a kinetic rope to replace my snatch strap.
    What length do people usually go with? One better than the other for most cases?
  17. Nov 24, 2023 at 5:29 AM
    #177
    TCB2020
    TCB2020 Well-Known Member
    2020 Tacoma TRD Sport
    None
    Thanks for posting! I'm a newbie to recovery efforts and all information is appreciated.
  18. Dec 21, 2023 at 4:42 PM
    #178
    andthen
    andthen Well-Known Member
    Fred
    22DCLB Lunar Rock
    I ran into a similar issue yesterday when I was pulling a Chrysler Concord (I think that’s what it was) out of my uncle’s back yard. After some searching, I found this and look forward to picking it up and trying it next time.
