Recovery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmh16, Mar 10, 2011.
  1. Mar 10, 2011 at 7:25 PM
    gmh16
    gmh16 [OP] Active Member
    Quick question,
    I am wondering if I will be able to fit a recovery shackle (d ring) to the stock front passenger towing eyelet. If so what size shackle should I use? I only have SR5 not TRD OR.
    Any help would be appreciated.
  2. Mar 10, 2011 at 7:27 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    yes you can, i used the one on the driver side to get my pulled out once. I used just a 5ton rated shackle.
  3. Mar 10, 2011 at 7:36 PM
    gmh16
    I've seen many posts that say to not use the driver side loop because it can't stand the stress because it is just welded on to the frame. Is that just people being a bit too careful?
  4. Mar 10, 2011 at 7:41 PM
    snowgod06
    Rob
    06 Access Cab
    I cant tell you yes or no on that, but i can tell you from the times i've used it and been STUCKKKKKK it worked like a charm. But it should fit on the passenger side as well.
  5. Mar 10, 2011 at 7:43 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I've been wondering about this as well:notsure: Me thinks it would be ok, as mine looks to be welded on fairly well
  6. Mar 10, 2011 at 7:47 PM
    gmh16
    so you just threw on a clevis ring or d ring on the loop or did you just wrap the recovery strap around the loop so it cinches on itself?
  7. Mar 10, 2011 at 7:56 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
  8. Mar 10, 2011 at 8:00 PM
    gmh16
    So you cant just use the original eyelet?
  9. Mar 10, 2011 at 8:02 PM
    mustangwilly
    IL
    Yes you can but it would be a fairly small one.
  10. Mar 10, 2011 at 8:09 PM
    gmh16
    I haven't measured...is the hole <3/4"? If it is I still might be able to fit a 5/8" clevis (I think the load limit would still be large enough...maybe?)
  11. May 12, 2011 at 7:26 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Manual states not to use the loop welded on the drivers side- :eek:
    The manual states for emergency towing to use the towing eyelet or hook mounted on the passenger side depending on what is installed on your truck. Among other things, it also says to avoid damaging eyelet/hook do not pull from the side or at a vertical angle-always pull straight ahead.
    I am working on fabbing a mount now which would be beefier and could handle a 3/4" shackle like above, but for emergency situations, and or for those who do not have a custom mount, bumper, etc. with shackle mounts, or basically have a stock truck, I believe just opening up the eyelet opening just enough to be able to fit the 7/8" pin size would work. I did not take a before and after shot, but the eyelet stock has a 1/2" boarder around the opening more or less. I did not change the side boarders, but I opened up the hole by going down, or away from the typical contact point while towing or recovering pulling forward. I think it would work for occasional use, what do you guys think? And, its a free mod. If your off roading your stock truck and have no shackle mount options up front, this could be better then nothing for now. For about 10 bucks for a shackle, and a little paint and your good to go. Pictured below is my eyelet modified for a 3/4" shackle, ready to re mount.
  12. May 12, 2011 at 7:33 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    :eek: x2!:D On our NorCal Snow Wheelin trip we recently took, we were using those to jerk and pull us stock tacos across the snow when we were high centered (to be honest, even some of the others got stuck...the snow was 4 feet deep). I can at least say that they must be really strong to survive what we were putting them through.
  13. May 12, 2011 at 7:45 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I believe if people are using the non approved welded hook with success, the modified eyelet with a 3/4" shackle should be a stronger set up. Considering Toyota designed the eyelet for emergency use, it should be strong enough to handle our truck's weight, and a 3/4" shackle has a rating of about 10,000lb. We may not need a larger mount for occasional use?
