Recycling old fluids
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kurtw, Jul 5, 2020.
  1. Jul 5, 2020 at 11:41 AM
    kurtw
    kurtw [OP] Extra Regular
    Kurt
    Leander, TX
    07 PreRunner Double Cab TRD Sport - Sold / 2016 4runner Trail Premium
    I'm going through my garage and I have a ton of old brake fluid, AT fluid, power steering fluid, etc. I usually drop off my used oil at Wal-Mart (since it's free and they recycle the filters as well) but they said they won't take other old fluids. I don't want to dump these down the drain, for obvious reasons. Where does one take these types of fluids to for recycling?
  2. Jul 5, 2020 at 11:43 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    The landfill,nobody will take them for recycling.
    BillsSR5 likes this.
  3. Jul 5, 2020 at 11:47 AM
    fatrip
    fatrip Well-Known Member
    Vince
    Upstate NY
    07 Taco 4D Short
    Bilstein 5100's , 885.
    Pretty sure Auto zone takes all those. Or a haz recycling facility. All else fails, mix with motor oil and give to WM.
    Shellshock, gabbo2112 and BillsSR5 like this.
  4. Jul 5, 2020 at 11:47 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I would check out the interwebs I just deposed of an old refrigerator at designated Enviro safe place/manner theres resources on the net
  5. Jul 5, 2020 at 12:00 PM
    kurtw
    Kurt
    Leander, TX
    I tried a few local mechanics, none of them take old fluid for recycling. I also couldn't get a straight answer out of the 3 I called what they actually do with them, or where they take them. They all just said they recycle the fluids they change there.
  6. Jul 5, 2020 at 12:02 PM
    BillsSR5
    bill
    2014 SR5
  7. Jul 5, 2020 at 12:14 PM
    kurtw
    Kurt
    Leander, TX
    I've checked here already and called them. No dice. They just say they don't accept automotive fluids. Local county landfill takes old paint and household stuff on certain days but they also said no to the automotive fluids.
  8. Jul 5, 2020 at 12:22 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    City household hazardous waste collection center. Every largeish city should have one or something like it.
    RHHousehold likes this.
  9. Jul 5, 2020 at 12:41 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Walmart will take AT. I've done so myself, telling the tech as much and seen him dumping it in the same collection container as the motor oil. PS for the Tacos is Dexron III, an AT. Brake oil, as suggested, I've mixed with motor oil and taken it to walmart.
  10. Jul 5, 2020 at 12:53 PM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    All my motor oil, AT fluid, gear lube, brake fluid, and power steering fluid gets poured into a 15 gallon container and emptied at the city dump. They have never complained.
  11. Jul 5, 2020 at 1:00 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Auto part store most likely will take it.
    At my dealer we 2 used fluid tanks. 1 tank for coolant and 1 for engine oil/trans/power steering/gear oil/brake fluid.
    Might be able to get the jiffy lubes guys to let you dump it there, wait till they arent busy and bring a cold soda/gatoraid or a beer if you want.
  12. Jul 5, 2020 at 1:01 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Emptied in the landfill or in their collection containers for fluids? If in the landfill, do they know you are dumping fluids?
    In Auto Repair for Dummies, it says, "Never dump oil onto the ground, throw it out with your regular garbage, or flush it down a drain. It’s a major toxic pollutant that needs to be treated accordingly. In many locales, putting oil filters into a landfill is against the law, so you may risk a fine."
    Marc70 likes this.
  13. Jul 5, 2020 at 1:10 PM
    Dens71TA
    The city dump has two 1000+ gallon waste oil tanks. Where it goes from there, who knows.
  14. Jul 5, 2020 at 1:13 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @Dens71TA That's what I was trying to get clarification from post#10. If he dumped in waste bins, or dumped it in the landfill, as he didn't clarify.
  15. Jul 5, 2020 at 1:17 PM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    Go to a Walmart that doesn’t have an auto service center. The hazmat drop off area is usually up front near the customer service desk. You can just walk up and drop off in the bin and if you’re that worried use some sort of opaque container. I don’t think anyone will be monitoring that closely.
  16. Jul 5, 2020 at 1:17 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'm lucky my county takes different kinds of haz waste a few times during the year. Come to think of it, the Rona might have shut them down. I should look since I have some I could get rid of.
  17. Jul 5, 2020 at 1:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    should be able to take it to any name brand auto parts store.... never had an issue recycling coolant, oils of any kind.
    BillsSR5 and RHHousehold like this.
  18. Jul 5, 2020 at 4:42 PM
    BillsSR5
    bill
    2014 SR5
    from what I hear if you can mix old motor oil and trans fluid,coolant together and put it in a jug it all goes to the same place anyways. around here where I live they use it to burn in the furnace during the winter time since its all mostly oil based it doesn't matter. in fact I work in heavy equipment company they will burn all the old used oil from company machines and vehicles in the furnace they have at their corporate building.
  19. Jul 5, 2020 at 4:59 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Just dump them down your neighbors drain and then call the cops on them. J/k don’t call the cops....
    Aardvark13 likes this.
  20. Jul 9, 2020 at 6:56 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
