RED top optuim or block heater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcanders, Nov 24, 2010.
  1. Nov 24, 2010 at 6:58 AM
    bcanders
    bcanders [OP] Active Member
    I live in Washington and we are having a pretty cold winter. -20 this morning. Should I get a block heater or a red top battery ? I noticed in the morning it takes two turns of the key to get my new 2011 truck to start. First attempt it does not want to start. Second attempt it starts. What would you do? Thanks
  2. Nov 24, 2010 at 7:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you chose the battery route...go with a YELLOW top Optima. I've owned both red & yellow tops. I think the Yellow tops are far superior than the red tops.
  3. Nov 24, 2010 at 7:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That new, I'd go for the block heater. Your battery shouldn't be having issues on a 2011 truck. If it is, I'd have a chat with the dealer. I'd also keep the battery on the top of the list of future upgrades if you're consistantly in that cold of a climate.
  4. Nov 24, 2010 at 10:21 AM
    Di Trut
    Di Trut Well-Known Member
    without a doubt get a block heater installed...i can't believe you don't have one already!
  5. Nov 24, 2010 at 10:32 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    If it starts at -20 on the second try I'de forget about both of your choices. Might consider a synethic oil, as the main and rod bearings might be starving for oil at that temp.
  6. Nov 24, 2010 at 10:37 AM
    Di Trut
    he should DEFINITELY have a block heater. you'd be stupid not to have one in that climate.
    synthetic oil is another good thing to have for a cold climate.
  7. Nov 24, 2010 at 10:50 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Check out the Wolverine heaters. I have been thinking of getting one. Keeps the oil itself from getting so thick when cold.
