RedLantern's "Brokanic" build
Discussion in '2nd Gen. Builds (2005-2015)' started by RedLantern, Feb 9, 2013.
  1. Dec 2, 2014 at 1:01 PM
    #201
    RedLantern
    RedLantern [OP] Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Ended up going with the UCON From URD. Gadget and Scott helped a bunch to make it a success.
  2. Dec 2, 2014 at 2:40 PM
    #202
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Damn that sounds wicked!
    Noticed your transmission is hanging way too long on shifts, especially 1st to 2nd. You getting a shift kit anytime soon? Either that or you'll need a new trans in the near future :p
  3. Dec 2, 2014 at 2:43 PM
    #203
    RedLantern
    Honolulu, Hi
    I noticed that too. Plan to get valve body upgrade soon in the next few months. How's your build coming along? I haven't checked your thread in a long while lol.
  4. Dec 2, 2014 at 3:00 PM
    #204
    ThomasMore66
    Dallas/Fort Worth & Durango
    I discovered with my SC that if I was getting tire spin (slick paved road) at the 2-3 shift I hit the rev limiter before it shifted. That freaked me out the first time.
  5. Dec 2, 2014 at 3:18 PM
    #205
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Please don't its embarrassing :p
    Im basically hung up by money right now. Getting out of the military and getting a new career so big purchases have been reduced. I was strong armed into getting some $800 CO's which re-depleted my exhaust fund :eek:. I get some bonuses in Feb though and should be able to get everything installed then.
  6. Dec 2, 2014 at 3:27 PM
    #206
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I feel like this should be stickied (tors build also obviously) and ever member should have to view it. This is what ive been wanting to do for a couple years now, and in a few months should be boosting away. Im very i.terested to see long term survival of the engine at this level of boost. Any plans to go a little higher stock? And how many miles are on ur truck?
  7. Dec 2, 2014 at 3:47 PM
    #207
    RedLantern
    Honolulu, Hi
    Ah I know how that goes man. With this build I've learned how well my patience was tolerated lol. I always saw it as "I've waited this long...might as well take my time." Plus this thing is my daily so had to dish out the CC to cover expenses if I had no cash. Gotta pay to play lol
  8. Dec 2, 2014 at 4:08 PM
    #208
    RedLantern
    Honolulu, Hi
    Too much power! :D
  9. Dec 2, 2014 at 4:11 PM
    #209
    RedLantern
    Honolulu, Hi
    NIce man. Do it if u got the patience and and or a second vehicle. Expect your truck to be down depending on your knowledge of wrenching and such. Where u plan on getting your hot side/headers fabbed?
    At most I'm probably gonna go up to 7.5psi. I'm pretty happy at 6psi too. We'll see. I just made 70k miles. 2006 double cab
  10. Dec 2, 2014 at 4:45 PM
    #210
    natewills21
    natewills21 Well-Known Member
    Nathan
    Pittsburgh PA & Morgantown WV
    09 Tacoma
    3 inch Procomp Lift Bilstien 5100 Fox Shocks Hornblasters Train Horns Fuel Maverick 18x12 Toyo MT 33x12.50r18 Custom Retrofits Homertaco Custom Grill Full Polk Soundsystem with 2 Kicker Subwoofers Custom Camo Wrapped Interior with Coverking Seat Covers
    You may have answered this question before but is there anything else I would need to upgrade in order to run the turbo kit?
  11. Dec 2, 2014 at 4:53 PM
    #211
    yota243
    E.J.
    north Alabama
    There is a place close called city diesel, and that is th front runner for fabbing right now, as since turbo related stuff is about all they do (albiet on diesels) . Although, recently i learned the my in-laws that are pretty race oriented are good friends with some turbo-ers, one of which apparently builds turbo manifolds, so i may talk to him as well
  12. Dec 2, 2014 at 6:38 PM
    #212
    RedLantern
    Honolulu, Hi
    Depends what you already have... You need quite a lot actually cause there isn't a turbo Kit for our trucks.
    Turbo, Turbomanifolds, Intercooler, charge pipes, a whole bunch of fittings, Fuel injectors, Bigger fuel pump, ECU to tune and much more. thats just thinking off the top of my head.
    i wish we had more fabricators in hawaii, so limited on an island. If there is, they charge an arm and a leg just because they can. make good use of your sources and ask lots of questions. Tor has been a big help and i awarded him with some cookies last year lol.
  13. Dec 2, 2014 at 7:26 PM
    #213
    yota243
    E.J.
    north Alabama
    Yeah hes a genius, and he has walked me thru my wish list. Its crazy the it was cheaper to have a tx company fab for u and ship it to hi than get a price gouging local shop to do it.
  14. Dec 2, 2014 at 8:23 PM
    #214
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just watch that video again, and from my computer this time. Damn that truck hauls some azz!
  15. Dec 2, 2014 at 10:31 PM
    #215
    RedLantern
    Honolulu, Hi
    Yea man i just sink right in. Gonna do the 7.5psi spring tonight. We'll see how that goes.
    Tor, do u have a boost controller? Looking to getting one. I wanna regulate it with a boost controller.
  16. Dec 2, 2014 at 10:44 PM
    #216
    kumz
    kumz Well-Known Member
    super sick!! nice build man
  17. Dec 3, 2014 at 6:11 AM
    #217
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I did. I had the Greddy ProFec B2. Loved it. Gave it to my girlfriend though. I had a 10 psi spring, and used it to regulate the boost to 14.7 psi. In days prior, I also used it to increase boost from 5 to 8 psi. Currently I just run the ~7 psi spring. :cookiemonster:
  18. Dec 3, 2014 at 8:26 AM
    #218
    RedLantern
    Honolulu, Hi
    Awesome. I'll probably end up getting the AEM truboost.
    So I did the 7.5psi spring last night and sent in my Data log. I had my go pro setup to take a video but I forgot to hit record! I'm an idiot.... Lol. Anyways i Got email from Scott this morning and all my reading look great! Looks like I'm tuned at 7.5 psi. Just gotta see if any codes pop up.
    I also picked up a separate valve body last night for the transmission. Will be sending that in to get upgraded. Still debating on IPT or Level 10. I know there's some guys who went with IPT here but gadget also went with level 10. anyone know the process of this?
  19. Dec 3, 2014 at 8:36 AM
    #219
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know Gadget recommends IPT.
    Lucario Runner did a swap in Toon714's. There are also a few more people on here who've done it.
    Glad to hear it is the tune is working spot on. :thumbsup: Better get that new video. Might as well make a 40-90 acceleration video while you're at it. ;)
  20. Dec 3, 2014 at 9:52 AM
    #220
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Everything I heard, they are both equally as good. However, you can't go wrong following URD's advice :thumbsup:
