RedLantern's "Brokanic" build
Discussion in '2nd Gen. Builds (2005-2015)' started by RedLantern, Feb 9, 2013.
  1. Oct 29, 2015 at 5:12 PM
    #341
    RedLantern
    RedLantern [OP] Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Just ordered the main and rod bearings for the spare motor that will be built. I originally called LCEngineering for them since it wasn't listed but they told me to order it from Jegs because it was cheaper from them. So they gave me the part numbers to order.
    Here's the part numbers
    CB190A - rod bearings $13.99
    MS2298A - Main bearings $66.99
    These are clevite parts.
    Will be ordering main seal and thrust bearings from Toyota soon. Then I can start working on the bottom end.
    MadTaco461 and nfs257 like this.
  2. Oct 30, 2015 at 4:51 AM
    #342
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    What all are you building....?
  3. Oct 30, 2015 at 5:09 AM
    #343
    RedLantern
    Honolulu, Hi
  4. Oct 30, 2015 at 5:12 AM
    #344
    j0shu4
    Just rebuilding the motor or going full Metal jacket? Good advice on the denso pump.....I thought walbro would be good as long as it wasn't a knock off. Guess not, fool me once. Ill never support anyone to buy that garbage. You know what denso model supports 315, I looked, many don't put out their lph. Found a 255.....
  5. Oct 30, 2015 at 7:42 AM
    #345
    RedLantern
    Honolulu, Hi
    Just rods n Pistons for now. Still debating if I wanna do head work.
    Here's the fuel pump that I found online.
    http://www.densofuelpump.com
    Good thing about these is that u should be able to find them locally.
  6. Oct 30, 2015 at 3:01 PM
    #346
    j0shu4
    Hope so. If not I'll next day air. Tired of not having a grocery getter.......thx
  7. Jan 6, 2016 at 12:56 AM
    #347
    RedLantern
    Honolulu, Hi
    So the truck just died on me. Drove less than 1/4 mile and it started limping. Then smelt an electrical burning smell. Saw the cel light come on but didn't check it before I killed the power. Now the cel isn't there anymore and truck won't start. Checked under the hood and can't trace the smell. Called my friend who builds cars for a living and he asked if I had anything connected to ecu. He thinks it could be that. Stuck my head near there and I could smell the burning scent from there. He thinks it's the ucon but will find out once I put my stock injectors back and see if it starts with the stock ecu. Currently waiting to get towed. This sucks balls Since it's my daily. Will find out tomorrow once I get working on it.
  8. Jan 6, 2016 at 1:01 AM
    #348
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    hope its a quick, easy, and cheap solution!
  9. Jan 6, 2016 at 1:09 AM
    #349
    RedLantern
    Honolulu, Hi
    I hope so too. If it's the ucon I'll be contacting gadget at urd. Hopefully i can get it running with the stock one.
  10. Jan 6, 2016 at 1:11 AM
    #350
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Youch! Here I am waiting for Gadget to get around to UCON for '12-'15. Hopefully it was just something small and fixable!
  11. Jan 6, 2016 at 1:15 AM
    #351
    RedLantern
    Honolulu, Hi
    Yea man. I'll wrench on it in the morning. Had a long day and it had to end this way. It's funny cause every time I'm about to leave on a trip, something ends up happening to the truck lol
  12. Jan 6, 2016 at 1:58 AM
    #352
    VolcomTacoma
    Jeff
    NorCal
    Well, good luck, brother!
  13. Jan 6, 2016 at 6:29 AM
    #353
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That'll be the best thing to do. Swapping back in the stock injectors and seeing if it will drive. In the mean time, just to try starting it, you could pull the UCON, then see if it starts up. It will be very rich, but you only need it to start. If it starts, you can kill it, then swap out the stock injectors and test drive it.
    If it is too rich to still start, then you'll have to swap out the stock injectors regardless.
  14. Jan 6, 2016 at 11:45 AM
    #354
    j0shu4
    Did that ucon come with a harness or is it diy?
  15. Jan 6, 2016 at 12:07 PM
    #355
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    for his, it should be plug n play
  16. Jan 6, 2016 at 12:31 PM
    #356
    RedLantern
    Honolulu, Hi
    Correct. It's pnp that's connected. It's setup kinda like a piggy back.
    So I took he ucon out, connected the stock ecu and it started! With all the fuel dumping in with the bigger injectors, my truck sounded like it was cammed lol. Will be changing out the injectors to stock now so I can drive it around. Smell is definitely coming from the UCON.
  17. Jan 6, 2016 at 12:40 PM
    #357
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thats no bueno. but at least you know what problem is. whats the warranty like on the Ucon? First I've heard of one of their EMS' having an issue. I'm sure Gadget will take care of you right?
  18. Jan 6, 2016 at 12:47 PM
    #358
    RedLantern
    Honolulu, Hi
    Not sure on what warranty is. I just emailed gadget and asked how to proceed. I find it odd as well. I bought it back in October of 2014. I'm sure he'll help me out.
  19. Jan 6, 2016 at 12:50 PM
    #359
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    oh thats not long at all then.. and since its plug n play and not a DIY splice job.. there really shouldnt be any issue on your end...
  20. Jan 6, 2016 at 3:28 PM
    #360
    VolcomTacoma
    Jeff
    NorCal
    Definitely this! But again as said above, this is the first I think we've heard of this happening to the UCON, so hopefully it was just a finger slip during the manufacturing and a wire didn't get soldered right or something.
