RedLantern's "Brokanic" build
Discussion in '2nd Gen. Builds (2005-2015)' started by RedLantern, Feb 9, 2013.
  1. Jan 6, 2016 at 3:34 PM
    #361
    RedLantern
    RedLantern [OP] Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    So first code came up was p0102. I didn't clear it. Went back to menu on scan gauge and checked code again and it's showing p2000 instead of the p0102. Any ideas?
  2. Jan 6, 2016 at 4:19 PM
    #362
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Idk about the mass air one, mine threw that and I could reset one, but another was permanent and showed up even though CEL was off. Due to over oiling air filter. Maybe yours code is stored from previous? And the other one could be from the incorrect A/F mix you're getting.
    These codes are from after the UCON was disconnected?
  3. Jan 6, 2016 at 4:27 PM
    #363
    RedLantern
    Honolulu, Hi
    This is running off the stock ecu. I just cleaned the maf for p0102 and it still pops up In the beginning. When I clear the codes it bogs out then runs again.
  4. Jan 6, 2016 at 4:41 PM
    #364
    RedLantern
    Honolulu, Hi
    Friend said that the p0102 is causing it to throw the p2000. I'm not sure how to test of its wiring that's bad.
  5. Jan 6, 2016 at 5:01 PM
    #365
    RedLantern
    Honolulu, Hi
    Think I figured it out. Efi #2 fuse popped. It's weird that it did. Gotta walk over to oreilly lol
  6. Jan 6, 2016 at 5:06 PM
    #366
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    Sorry, kinda confusing, so you cleaned the MAF and then Cleared the code? When I did the same to mine, the code still pops up, like it is permanently stored, even thought the light is off.
    I'd test the MAF first if you can find the specs. How does the UCon work, does it take the signal from the MAF and adjust the signal for the ECU?
    *edit read your post about the fuse, hope that solves it
  7. Jan 6, 2016 at 5:23 PM
    #367
    RedLantern
    Honolulu, Hi
    Ok. Fuse fixed the problem. Now it runs without codes so far on idle.
  8. Jan 6, 2016 at 5:46 PM
    #368
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Nice!
    So I wonder if the fuse popping caused the ucon to act up, or vice versa.
  9. Jan 6, 2016 at 7:56 PM
    #369
    RedLantern
    Honolulu, Hi
    Yea I'm confused as well. Not sure on the cause of this.
  10. Jan 6, 2016 at 11:45 PM
    #370
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    A blown fuse wouldn't cause a problem, it stops the problem from causing further damage.
  11. Jan 7, 2016 at 5:08 AM
    #371
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With the electrical burning smell, blown fuse, and truck working fine without the UCON. Loose connection, or component burnt up on the board.
    Should be an easy enough fix.
  12. Jan 7, 2016 at 9:45 AM
    #372
    RedLantern
    Honolulu, Hi
    Yeah I'm hoping that too. Regardless it will be sent to Urd. Gadget emailed back saying they'll happily look at it. It'll be sent out after work today.
    Drove my truck to work this morning without any hiccups. Im glad I'm able to drive the truck. I think I'll be looking into another car when I get back from Japan for my wife so that we have a spare vehicle on hand.
  13. Jan 7, 2016 at 10:37 AM
    #373
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    R32???? ;)
  14. Jan 7, 2016 at 10:38 AM
    #374
    RedLantern
    Honolulu, Hi
    Haha. Dude I wish. It's probably harder to make it legal here in hawaii.
  15. Jan 7, 2016 at 10:44 AM
    #375
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Jan 22, 2016 at 7:22 AM
    #376
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    hey man what plugs are you running? im about due to replace mine and still have a glimmer of hope that I can be boosted in the not so distant future, so I figure I would go ahead an replace mine with what I would need down the road.
  17. Jan 22, 2016 at 9:01 AM
    #377
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Lot of guys run IK22. What im running. OE for supercharger applications. I believe Gio runs just regular coppers.
    RedLantern[OP] and yota243 like this.
  18. Jan 22, 2016 at 10:42 AM
    #378
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If preparing for boost, run the IKH22's such as he said^^^. Even if not, you won't have any driveability issues with them over the 20's.
    yota243[QUOTED] likes this.
  19. Jan 22, 2016 at 10:54 AM
    #379
    yota243
    E.J.
    north Alabama
  20. Jan 22, 2016 at 11:01 AM
    #380
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct. Those.
