Redlining the 3.4L Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by bawilson21, Oct 20, 2009.
  1. Oct 20, 2009 at 3:39 PM
    bawilson21
    bawilson21 [OP] Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Hey there, I was just curious of some of the negative affects that could come from Redlining the Engine. Obviously its not good, but say you were being an idiot and happened to go past the 5.5K Redline on the 3.4L engine with a manual trans near or slightly past 6K RPMS just once. What sorta Ill flavored things might we expect? Engine stalling often? After I hit around 6K (and immediately let off, I was abkle to go maybe 1/2 mile before it stalled while turning at an intersection, and a few more times when letting the engine idle when coasting to a stop. A few hours later after the engine had a chance to cool down, I went in to check everything and it appeared to be working fine and nothing was noticable. Everything felt fine and it shifted well. I thought I noticed smoke when I went to turn the engine off coming from the hood after hiting 6K RPMS but upon further inspection (just by popping the hood and looking/sniffing around) everything looked fine. I was thinking that maybe it couldve been the Timing belt (as its slightly passed the 90K mile and 9 year mark) or perhaps something with the Battery/alternator while spinning at those speeds. The battery doesnt seem to be in the best shape physically but Ive never had a problem in the Arizona heat with starting other then this one time which was at night. The Engine mustve stalled some 7 times before I got to my location afting hitting 6k RPMs while traveling some 2-3 miles.
    Inputs?
  2. Oct 20, 2009 at 3:45 PM
    j_cyrus
    j_cyrus Well-Known Member
    Rickman TN
    I've bounced mine off the rev limiter a few times and it hasn't hurt it? I dunno, good luck, I hope you find the problem.
  3. Oct 20, 2009 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What did you do to get it to 6K? Down shift into a gear going to fast?
  4. Oct 20, 2009 at 3:56 PM
    bawilson21
    Bryan
    WA
    I was accelerating - trying to push the envelope a little bit. I let it go for two long before I shifted up as it seemed to go right up there.
  5. Oct 20, 2009 at 3:57 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I had a similar issue on a vehicle where i way over revved it and it caused a valve to "float" coming in contact with a piston. This caused a bent valve shaft. With a bent valve stem the valve would not seat properly causing low compression, thus making the engine stall at low RMPs. The vehicle was a motorcycle and over-revving was 11k a little bit different from your situation. However, there are tons of other explainations for whats happening, tough to say through a forum.
    I do not think its a heat issue. Over-revving does not cause alot of extra heat, especially for the amount of time your talking about.
    Best of luck, if the stalling goes away just keep your fingers crossed and dont do it again.
  6. Oct 20, 2009 at 3:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You didnt hurt anything. Not sure why it stalled, but there is a rev limiter set at about 6100 rpm. The piston speed on the 3.4 is pretty low, even at 5500 rpm, and you would have to spin it to a bit over 6500 before worrying about damaging it. Hell, In the sand dunes, I rode my 2.7 right on the limiter for mins. on end. Never had an issue.
  7. Oct 20, 2009 at 4:00 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    The Rev Limiter kicks in before you could over Rev The engine. thats why its there, On occasion I bounce off of mine when im wheeling...
  8. Oct 20, 2009 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Moderern engines are ussually limited about 1500 to 2000 rpm, or more, below where they would need to be to get any valve float.
  9. Oct 20, 2009 at 4:09 PM
    bawilson21
    Bryan
    WA
    I'm not quite sure what you mean by a valve floating. I would assume this is bad?
  10. Oct 20, 2009 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its when the valve no longer makes contact with the lifter/cam lobe. You have to spin an overhead cam engine pretty high for that to happen.
  11. Oct 20, 2009 at 4:40 PM
    bawilson21
    Bryan
    WA
    Oh, and no CEL ever came on during this whole process, except of course after it stalled when the engine wasnt on (normal).
    Maybe it was just the engine sensing all the fuel at once and decided it was going to adjust the fuel/air mixture it was going to need. Then again, maybe Im giving the 5VZ too much credit. Either way, at this point, I'll just not do it again and pretend like nothing happened and pray that nothing goes wrong. :pray:
  12. Oct 20, 2009 at 4:40 PM
    Yoytoda
    Roland
    completely stock
    Agreed but he did say the redline is 5.5k and he went over 6k and didnt say he hit a limiter. i admit valve float is highly unlikely but a 2000 tacoma as durable as they are is not designed for high revving. I dont know why it would be stalling though, seems strange...a 2000 with high miles i wouldnt doubt the valve springs are getting tired making it a little easier to float the valves but again, unlikely. I vote get a compression test done if it keep stalling
  13. Oct 20, 2009 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He couldnt have gone over 6k without hitting the limiter. If the compression was off, his truck would be running rough.
  14. Oct 20, 2009 at 4:46 PM
    bawilson21
    Bryan
    WA
    It seems to still be running as smooth as a baby's bottom. :eek:
  15. Oct 20, 2009 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your fine. ;) FWIW, running it to the redline now and then is not a bad thing. I try to do it every couple of weeks. :eek: Just dont break any traffic laws.
  16. Oct 20, 2009 at 4:51 PM
    Yoytoda
    Roland
    completely stock
    sorry didnt read this. Thought you over-revved downshifting. I agree with others you can hit your limiter without issues, thats it purpose.
  17. Oct 20, 2009 at 4:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought the same thing at first :)
  18. Oct 20, 2009 at 4:53 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    We do not condone any type of illegal street racing here on TW..I have the power to cull your post from this thread.:D
    Sound familar, Mod?:p
  19. Oct 20, 2009 at 4:53 PM
    bawilson21
    Bryan
    WA
    Cool, Thats a Relief. I'll still run her easy for the next while. I've running her as hard as I've been working. Time we both deserve a break. Too bad only one of us will get it. HA!
  20. Oct 20, 2009 at 4:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Redline can be reached in first gear without any laws being broken. Also, when off roading......:cool:
    With that, I wave to you in a friendly manner. :)
