redoing my alarm
Discussion in 'Technical Chat' started by 07TacoRidah, Sep 28, 2010.
  1. Sep 28, 2010 at 8:55 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    I got a new alarm the other day and I want to start off from scratch. As of now it has aftermarket door locks (no OME lock/unlock switch - has 1 small on/off/on momentary switch), and aftermarket siren (from previous alarm installed).
    First, I want to install the door locks to the momentary switch how it would be somewhat like normal, but just with one lock/unlock switch. If anyone has a diagram or knows where to find one. Or can tell me what I need to do.
    Second, I want to wire up the alarm so that I can unlock the driver door on the first hit of the unlock button on the alarm transmitter. Then on the second, the passenger will open. Also it has a ignition lock to it, which I would also like to have (vehicle is in gear doors lock, vehicle is in park doors unlock).
    Third, this is just something I am curious about but there is an aux wire to this alarm which a remote engine start can be added, how would I go about doing that and would I need a whole new system? I do not want to have a bunch of remotes hanging from my key chain, it's annoying for me.
    If I can use the same alarm (have it work "all-in-one" style), any diagrams? thank you.
    The alarm I am working with is a ScyTeck SA 100 Series alarm - aftermarket door locks and siren unknown BUT work like new.
