Reese hitch- any information?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Oct 26, 2014.
  1. Oct 26, 2014 at 4:14 PM
    vijay
    vijay [OP] Well-Known Member
  2. Oct 26, 2014 at 4:29 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Look into the Curt hitches, you can buy them custom cut for the Tacoma so you don't have to drill anything
  3. Oct 26, 2014 at 4:39 PM
    vijay
    I looked at Curt as well. It is around $286 and look very similar to Reese.
  4. Oct 26, 2014 at 4:43 PM
    ole
    ole unproductive
    Rock County Wisconsin
    2025 Tacoma SR Double Cab
    Keep looking. I have seen Curt hitches for a lot less than that!
  5. Oct 26, 2014 at 4:53 PM
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    I got a curt with wiring harness for $145 shipped on eBay.
  6. Oct 26, 2014 at 6:42 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  7. Oct 26, 2014 at 8:15 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Love my curt hitch. Their wiring harnesses I've had nothing but issues with though.
  8. Oct 26, 2014 at 10:26 PM
    vijay
  9. Oct 26, 2014 at 10:38 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I would be leary of this add. for 2 rezones
    (1) does not give a class rating on the hitch
    (2) mix and match side plates does not sound inspiring to quality
  10. Oct 27, 2014 at 5:18 AM
    Canufixit
    New England
  11. Oct 27, 2014 at 8:41 AM
    vijay
    Thank you Sir!!!!
  12. Oct 27, 2014 at 9:36 AM
    Canufixit
    New England
    Welcome, Just be sure it fits yours as well !!!!
  13. Mar 20, 2015 at 2:57 PM
    Mlarrosa91
    Mlarrosa91 New Member
    Matias
    Staten Island, ny
    2015 double cab 4 cyl
    Did anyone install one on their 2015? Good fit? Any tips or tricks before I go ahead?
  14. Oct 18, 2015 at 5:13 PM
    AtMR2525
    AtMR2525 New Member
    Art
    2005 2.7l 5-speed Prerunner
    I just installed one yesterday. Its a Reese pro series from wally world. 115 including shipping.
    The box arrived banged up. While installing I realised that a sideplate was bent in about a half inch. Bashed it on the curb to square it up. The install took some wiggling and prying and putting a jack underneath the hitch to get the holes to line up. Finally got the bolts in and started cranking it down.
    Thats where the fun started. While the install instructions request that "All M12 bolts to be torqued to 105ft-lb" the factory bolts stretched and snapped. So I replaced them with some grade 8.8s and torqued it to max for the bolt 75ft-lb. The question I have is, Are the factory nuts, welded inside the frame rail, designed to handle the stress?
    And why the f would ToMoCo use potmetal bolts to hold the Bumper, which is also "rated" for 5k tow 500lb longue load!?
  15. Oct 19, 2015 at 3:05 AM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    I bought a Reese Pro Series class 4 from Advanced Auto a couple yrs ago for under a C-note. Ordered online got $50 discount. Went and picked it up when it got there. Torqued bolts to 80 ft lb. No issues, holding up good. Easy 1 person install using a floor jack on a milk crate to hold in place.
