Reese wiring harness question
Discussion in 'Technical Chat' started by bunkerboy, Mar 3, 2013.
  1. Mar 3, 2013 at 10:11 AM
    bunkerboy
    bunkerboy [OP] Well-Known Member
    Gainesville, FL
    2014 Prerunner
    What's this doohicky? My right trailer brake light doesn't work and this is the reason why. Can I just bypass it or does it do something important enough to buy a whole new harness?
  2. Mar 3, 2013 at 10:25 AM
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    That's your converter to take the separate turn signal and brake lights from your truck and making it work with the single filment of the trailer turn/brake light. You will need to wire another one in its place.
  3. Mar 3, 2013 at 10:36 AM
    bunkerboy
    Gainesville, FL
    2014 Prerunner
    Damn, not what I was hoping to hear. So if I just cut and direct-connect the green wire from "RIGHT TURN" to "RIGHT TURN/STOP" ... what's it do, screw up the voltage or something?
    How readily available are these harnesses anyway? Mine came with the truck when I bought it.
  4. Mar 3, 2013 at 10:50 AM
    A3umph
    outside of KCMO
  5. Mar 3, 2013 at 10:55 AM
    joes06tacoma
    Joe
    Central Coast, CA
    If you disconnect the "stop" and both "right turn" and "left turn" wires on the car side, then wire the car side "stop" directly to BOTH the left and right "stop/turn" wires on the trailer side, that will get you brake lights on the trailer. That may be enough for now, eh?:) Otherwise, they sell those converters in just about every NAPA I've been to. They come in custom fit with direct plug in to your truck, or with just that box and some splice connectors. The ones that you have to splice are probably only $20.
  6. Mar 3, 2013 at 11:26 AM
    bunkerboy
    Gainesville, FL
    2014 Prerunner
    Okay I understand, thanks! I think I'll start calling around for a converter, especially if I can buy just that and not the whole harness.
    Any idea what the actual name of that converter is, so I can sound intelligent when I'm asking the parts guy?
  7. Mar 3, 2013 at 11:30 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Scour eBay... much cheaper than buying from a local RV supply house.
    But it is what it is... it's a trailer turn signal/brake light convertor.
  8. Mar 3, 2013 at 11:31 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Trailer light adapter or trailer wiring adapter.
    For any trailer with more than simply two bulbs, you want one that draws power directly from the battery.
  9. Mar 3, 2013 at 11:34 AM
    bunkerboy
    Gainesville, FL
    2014 Prerunner
    I just found an image of one on Reese's site. They simply call it a "taillight converter". Who'd have guessed.:D
    Off to the parts store!
