Refrigerators
Discussion in '3rd Gen. Tacomas (2016+)' started by snake6778, Jan 28, 2019.
  1. Jan 28, 2019 at 1:55 PM
    snake6778
    snake6778 [OP] Member
    This may be something I need to post in an overlanding forum (if you know a good one let me know).
    I want to get a refrigerator. I have a camper shell and do a lot of camping and would like to put a fridge in. Have any of you done this? Can I have one running 100% of the time? My truck never sits, I drive it M-F and usually both weekend days. My only concern is if it will drain the battery.
    Also, if you guys do have them, which ones do you have?
  2. Jan 28, 2019 at 2:00 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Lots of people have them. Mine is very old - probably from the early 80s. I run it on propane but it can also run on 110v and 12v.
    Lots of variables to consider but the short answer is you’ll likely need an aux battery unless you get very small fridge.
    Edit: I’ll be switching mine over to 12v and I installed a solar panel to keep the battery topped up, and will also be installing a second battery.
    TomTwo likes this.
  3. Jan 28, 2019 at 2:07 PM
    snake6778
    Which solar panel setup did you go with? I am OK for not having an aux battery if I use that, correct?
  4. Jan 28, 2019 at 2:18 PM
    Rujack
    It depends entirely on how much you use it. I could see the stock battery easily being drained overnight especially if it’s warm out...
  5. Jan 28, 2019 at 2:20 PM
    Rujack
    I mounted a renogy 100w panel to my roof rack.
    You’ll have to do some math. Someone else can tell you for sure, but I think it’s amps x volts = watts, to figure out how much you’ll be drawing.
  6. Jan 28, 2019 at 2:33 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I run one in mine. I have a dual battery setup set up with blue sea ML-ACR to isolate the auxiliary battery when parked. I run a group 27 AGM secondary battery rated at 75AH. I was able to run the fridge full time as long as I drove it daily.
    Blue Sea Systems ML-ACR 12V DC 500A Automatic Charging Relay with Manual Control https://www.amazon.com/dp/B001VIXLRO/ref=cm_sw_r_cp_api_i_eE4tCb2C24DRS
    Now I have 100watts of solar permanently installed on the truck that I can expand to 400watts (temporary mount) on extended trips. I also added a second (removable) auxiliary battery. I seldom have to worry about power with that setup as long as the weather is good.
    Renogy 100 Watts 12 Volts Monocrystalline Solar Starter Kit w/ 100W Solar Panel + 30A PWM Negative ground Charge Controller + MC4 Connectors +Tray Cable+ Mounting Z Brackets for RV, Boat https://www.amazon.com/dp/B00BFCNFRM/ref=cm_sw_r_cp_api_i_lG4tCbTDV604V
    I run a Whynter 45 quart fridge/freezer mounted on passenger side rear seat back. I would recommend an insulated cover no matter what fridge you get. Really helps with efficiency. I only run my truck set up like this through the spring and summer..
    Whynter FM-452SG Elite 45 Quart Slimfit Refrigerator with 12v Option Portable Fridge/Freezers, One Size, Gray https://www.amazon.com/dp/B01F88ANYQ/ref=cm_sw_r_cp_api_i_sF4tCb1RKV283
