Regearing after lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirthawker1313, May 26, 2010.
  1. May 26, 2010 at 8:54 PM
    dirthawker1313
    dirthawker1313 [OP] Well-Known Member
    im running a 6" lift with 295 70 17 in tires.i would like to hear from people who have actually regeared their tacomas after lifting them. do you have to regear both the rear and front when you have 4 wheel drive or can you get away with just regearing the rear. also what gear ratio are you running and why? what did it cost you to have it done?
  2. May 26, 2010 at 9:15 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    regearing is relative to tire size, not lift size. i'm running 315/75/16 on a 3" lift and yes there is a loss of power, but the MPG savings would keep me from regearing. dont need to pick up that little bit of power back when running 35s
  3. May 26, 2010 at 10:47 PM
    Manwithoutaplan
    ID
    I am running 35's with 53000 miles but i want to eventually with lockers.
  4. May 26, 2010 at 10:58 PM
    Manwithoutaplan
    ID
    If you do Regearing you will have to get both the front and back regeared. YOu can take a look at http://eastcoastgearsupply.com/ 3rd member assmbly were they send the gear put together and once you have yours in. you send it your old ones back to them for money back. WHen ever i get the money i going to do both front and back 4.56/ with Arb lockers. But it is going to set me back aways.
  5. May 26, 2010 at 11:02 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    i am running the same set up! dont regear no need!
  6. May 27, 2010 at 9:13 AM
    dirthawker1313
    the reason i was asking is i drove to california in it the other day and it was a gutless wonder on the highway .. not to mention eating gas like it was nothing.. i expected a loss in MPG so thats no big deal its the loss of power i dont like.
  7. May 27, 2010 at 9:18 AM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    do the re-gear I did! I love it! I'm running 4.56 and ARB lockers and love the set up. It is a bit expensive though and it is night and day.
  8. May 27, 2010 at 9:23 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You're at the point where you could use a regear. Now weather you NEED it or not, is only up for you to decide. By what you have said, I can say you WANT to regear and quite possibly NEED to for your circumstances.
    Use a gear ratio calculator to figure your before and after final drive ratios and you can adjust the rear end gears accordingly to achieve the final drive ration you are looking for. To answer another one of your questions, you do need to do both the front and rear R&P's at the same time. I do know a guy who decided not to but the end result was he drove a 2x4 instead of a 4x4. Wouldn't make much since to only do the rear.
