regearing -need advice please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hookedontronics, Dec 15, 2011.
  1. Dec 15, 2011 at 6:52 AM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I looked for a sticky and did a search but couldn't find anything.
    I was getting 19/20mpg consistently with my stock tires, just added 285/65-18's and i'm at about 15-16mpg now. I love the way my truck looks and sits now so nothing is going to change there, if that's what i get for mpg that's just fine but i am pretty sure i can regear and do better.
    Thinking of re-gearing for better fuel mileage, i have no clue what i have in there stock and what i i should go to for better mpg. I drive highway daily for my work commute, at about 75-80mph
    What would you guys recommend and what can i expect from re-gearing?
    Thanks
  2. Dec 15, 2011 at 7:35 AM
    Large
    Large Red
    I think with 33s, 4.56 gears puts you back to or close to stock. I'm not sure though.
  3. Dec 15, 2011 at 7:37 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  4. Dec 15, 2011 at 7:38 AM
    hookedontronics
    Jake
    Glenville, NY
    that would be true if the truck comes stock with 4.10. Is that what my tacoma has?
  5. Dec 15, 2011 at 7:39 AM
    mjp2
    NJ
    I think you have 3.73 gears.
  6. Dec 15, 2011 at 7:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^
    4.10's would put you back to stock, and a tiny bit over geard.
  7. Dec 15, 2011 at 7:47 AM
    Large
    Large Red
  8. Dec 15, 2011 at 8:02 AM
    hookedontronics
    Jake
    Glenville, NY
    What exactly does over geared mean? More power than stock at low end and a decrease in top speed?
  9. Dec 15, 2011 at 8:17 AM
    mjp2
    NJ
    Bingo!
  10. Dec 15, 2011 at 8:20 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    IMHO, Don't expect to get back to factory MPG with regearing. It might help some in some situations, but realistically you are still churning more rotational mass regardless of what your gearing is.
  11. Dec 15, 2011 at 8:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Top speed does not decrease As the speed limiter kicks in Before the truck Would reach It's theoretical Top speed.
    But the engine now Has more mechanical Leverage To overcome The additional mass. Every time I have re geared I have gotten back 2 miles per gallon.
  12. Dec 15, 2011 at 8:41 AM
    PreRunnerSeth
    Apex, NC
    I'm not saying it wont improve, just saying you wont get back to stock. I got back a couple at freeway speeds and very little in town.
  13. Dec 15, 2011 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I agree. Most gains I have seen have been in town, with the least gains seen on the freeway. But then I'm sure the end result is in individual driving styles.
  14. Dec 15, 2011 at 9:02 AM
    hookedontronics
    Jake
    Glenville, NY
    So if i go to 4.10 i'll be back at my stock power band and it should also decrease my rps at highway speeds of 75-80mph?
    If i go to 4.30 i'll have more low end power than stock and even less rpm at highway speeds of 75-80mph?
    And would i need to swap out the front as well since it's a 4x4? Will i run into any problems with my rear locker?
  15. Dec 15, 2011 at 9:09 AM
    PreRunnerSeth
    Apex, NC
    You will have to do the front too. The 2nd gens are limited to 2 gear choices due to limited manufacturers. For an automatic you can only go to 4:56 unless you change the carrier in the front to the carrier from a manual tacoma then you can go 4:88. you will be fine with locker.
  16. Dec 15, 2011 at 9:50 AM
    hookedontronics
    Jake
    Glenville, NY
    so it's 4:56 only? or my option would be 4:10 or 4:56?
  17. Dec 15, 2011 at 10:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can get 4.10's. The gears from the 2.7 interchange with the gears of the 4.0. The 2.7 has 4.10's.
  18. Jun 30, 2012 at 12:59 AM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    look, my 02 taco 2.7l had 4.20 stock gears by running on 33x12.50x15 Toyo M/t and it is not strong enough to pull the tires. so now regeared mine with 5.29 and from my 1st to 3rd gear i can zoom like a little car, remember you win some and you also lose some. you gain power and lose your top speed but when you think about your MPG- i recommend that you regear the bigger the better. bigger gears use less gas that all i can tell ya.:burnrubber:
  19. Jun 30, 2012 at 3:20 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I'm going with 4:10's in my truck in a few months. They seem to bring the truck back to a closer stock ratio without raising your highway RPM too much. And others are correct that your MPG will improve but you will not get back to stock.
    East Coast Gear Supply makes complete third members that you can order and then ship your old ones back. I think that's who I am going to go with as there are no 4X4 shops around here that I would trust to set gears right and ECGS guarantees their diffs for five years.
    4.56's are slightly cheaper because the carrier does not have to be replaced in the front differential ~$300 for that.
    If you want to go with 4:10's you might want to talk to local junkyards and try to find the diffs off of a 2.7L but that might be hard to find.
