Regearing Question
Discussion in '5 Lug' started by Stuie, Jun 18, 2012.
  1. Jun 18, 2012 at 12:05 PM
    Stuie
    Stuie [OP] Well-Known Member
    I am looking at regearing my 08 tacoma , Toyota ran my vin and only know the gear size but not the size of the rear end . I am located in ABQ NM and I need to find a place that can do the job
    Thanks
  2. Jun 18, 2012 at 12:08 PM
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    8.4 rear end. Not sure about a local shop that can do the work for you but East Coast Gear Supply can send you a 3rd member with gears and whatever else you want to install yourself.
  3. Aug 11, 2012 at 11:43 AM
    2manyhobbies
    2manyhobbies Member
    Austin, TX
    2012 access cad, base + extras
    Purchased June 2012. Mods in order: Windows tinted, Code Alarm, 18" Zen wheels with 245/45/18 tires, 2/3 drop, bump stops, and K&N repacement filter. More coming soon.
    Is it expensive to regear the rearend?
    The 4cyl Camry has either a 2.7L or 2.8L, and performs a lot better than the Taco with around the same gas mileage. Is it the rearend only? Or rearend and cams?
  4. Aug 11, 2012 at 12:08 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    The Camry has a different engine, it is a lighter vehicle and it is front drive.
    A rear end gear change is almost a grand if someone does it for you.
