Regret doing Rear Spring TSB?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scienceguy, Jun 22, 2010.
  1. Jun 22, 2010 at 11:26 AM
    scienceguy
    scienceguy [OP] Well-Known Member
    I know there are a lot of TSB threads, but the ones I have seen people are glad they did it. I am glad.:) But it got me thinking, is there anyone that has done the TSB that regrets doing it, or has experienced something they didn't like? :confused: I will probably do the rear spring and auto trans re-flash the next time I go to the dealer.
  2. Jun 22, 2010 at 11:43 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    My only regret is not doing it sooner. I love my truck much more now! I'd be surprised if anyone regrets getting the rear spring tsb done. :confused:
  3. Jun 22, 2010 at 11:51 AM
    AznGunner
    AznGunner Active Member
    Kingwood, TX
    09 PreRunner SR5 / TX Ed.
    What's the advantage to getting the rear TSB done?
  4. Jun 22, 2010 at 11:52 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I don't like the fact that I have to spend more money to level out the front.
  5. Jun 22, 2010 at 11:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You shouldn't have to.
  6. Jun 22, 2010 at 11:58 AM
    AznGunner
    Kingwood, TX
    Would the rear TSB make the ride rougher?
  7. Jun 22, 2010 at 12:18 PM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    To me the truck feels more balanced. Before the TSB the front felt firm and the rear was very soft.
    Now it feels more equal.
    Ours does sit higher in the rear now and looks like a leveling kit would help it not have the stance.
  8. Jun 22, 2010 at 12:33 PM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    I would say 100% i wish i done it sooner. The truck rides so much nicer now in many ways. First off i do feel it being a more firm of a ride but the ride is balanced so much better. Going into a sharp turn my truck does not lean into the curve anymore. Rides nice and flat right through. Also had the reflash done on the transmission. OMG so much better....like i said....wish i done it months ago but i'm very happy with the truck now!
    Also you do not have to add anything after if you wish. I am going with the 5100's in the front to level the truck so i can upgrade rims/tires.
    NO REGRETS. :thumbsup:
  9. Jun 22, 2010 at 3:06 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'm the opposite, I'm glad I got it because it made me finally buy a lift for the front.
  10. Jun 22, 2010 at 3:43 PM
    Janster
    Jandy
    Lancaster, PA
    When did you have it done?
    Put 200lbs in the bed for a month....it'll settle down.
    I've only got about 1" rake on mine and I think it looks perfect.
  11. Jun 22, 2010 at 5:18 PM
    dexterdog
    Oly WA
    2012 F150
    There are alot of things I shouldn't have to do, but I still do them anyway.
    The front rake reminds me too much of the old 70's era 2wd 3/4 ton trucks.
    I need to eliminate this.
  12. Jun 23, 2010 at 6:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The TSB puts a stiffer suspension on the back of the truck. The stock suspension is too soft to haul what it should. I was having issues with mine bottoming out with a motorcycle in the bed. TSB fixed the problem. The truck will ride a little stiffer but I honestly like it better sinc eit doesn't roll as bad in corners and isn't bouncy.
  13. Jun 23, 2010 at 6:38 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Is it true that the TSB on the rear suspension is only good to the first owner? I bought my 06 and was thinking about taking it in to see if the dealer would take care of it! Thanks in advance.
  14. Jun 23, 2010 at 6:59 AM
    jsbaggett
    jsbaggett Member
    its a technical service bulletin, it only applies to vehicles under warranty. if you have the same 3yr/36,000mi warranty as most then you are out of the service period and would have to pay them to do the work.
  15. Jun 23, 2010 at 7:00 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Pretty sure that it only happens in very rare 'good faith' cases outside of the 36 month, 36,000 mile warranty period.
  16. Jun 23, 2010 at 8:19 AM
    westport toyota
    westport toyota Well-Known Member
    100% better!! tsb and wheelers aal - no stiffness, motor bikes in back, halling ass everywhere. the way it should be
  17. Jun 23, 2010 at 8:39 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Nooooo regrets!! I know you will feel the same when you get her dunn.:D
  18. Jun 23, 2010 at 11:20 AM
    dbarn
    dbarn Well-Known Member
    Texas
    Tacoma 4X4 V6
    TSB and Billies up front set at 1.75. Now truck is level, ride is superior, truck handles heavy loads better, and with the addition of Hankook tires, it looks more like a 4x4 truck should. Am now a very happy camper.
  19. Jun 23, 2010 at 12:26 PM
    Jimmyjohn
    Jim
    06 SR5 4x4 DLB CAB
    Thanks folks for the quick response to my question. I knew I could count on you
  20. Jun 23, 2010 at 12:31 PM
    fsublume
    fsublume Member
    AZ
    2010 DC LB TRD 4X4
    Toytec OME Suspension, AVID
    where is the link to the downloadable pdf for the rear leaf TSB. Im taking it into the shop soon. Thanks!
