regular cab organizer
Discussion in '4 Cylinder' started by Tacoyota, Jul 23, 2009.
  1. Jul 23, 2009 at 10:38 AM
    Tacoyota
    Tacoyota [OP] senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I've been looking, but found nothing. Someone should make a bolt in tray system for that back wall, with a layer of sound dampening too. 1-2 different bottom tray depths, depending on how far back u slide the seat, and maybe 4-6 more trays higher up. Our old dodges at work have a similar system, so its not a new idea. I searched the web, but that doesnt mean i missed something.....
    :sadviolin:
  2. Jul 23, 2009 at 7:18 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    A sheet metal shop should be able to bend something up from aluminum and get it covered with bed-liner. I'd be happy at this point if Toyota had put the jack and stuff somewhere else. There's actually a lot of room back there.
    Motoretro
  3. Jul 23, 2009 at 8:07 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    Man, I'd be interested in something like that too for my reg. cab. I think the reason you're having trouble finding anything is because so few people buy regular cabs anymore. Not much of a market for that product. Be sure to post up here if you find anything though. As for the jack & stuff... where else could they put it?
    By the way... it was pathetically cheap of Toyota to skip the trim panel (and sound deadener!) on the rear wall of the cab. Even my '78 Datsun had that!
  4. Jul 23, 2009 at 8:30 PM
    Tacoyota
    08 4wd
    I figured it would require some dremel tooling ofr the jack, be in 1-3 pieces to fit around the belts, cabelas or jc whitney could sell it for $150 if it was decent quality
  5. Jul 24, 2009 at 6:52 PM
    motoretro
    Michigan
    Motoretro
  6. Jul 24, 2009 at 7:08 PM
    Tacoyota
    08 4wd
    I should invent the regular cab back wall mod. If I pillage a D.C., it might work:notsure:
  7. Jul 24, 2009 at 7:43 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    motoretro
    You said you had the TSB done on your truck plus they installed a sound deadner package. Was this an 09 specific TSB or ???
    I was going to order some RAAMAT sound deadner for it but if there is a factory fix for it then I will pursue that route. I would love to find an organizer or something for behind the seat.
    The wheels were replaced with 18" X-Runner rims just today.
  8. Jul 24, 2009 at 7:47 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    Jeremiekc post some pics of the X-runner wheels
    Im also interest in some info of this tsb, I have like 40ft^2 of fatmax in the garage, might just go ahead and use it.
  9. Jul 24, 2009 at 7:57 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I just got them on today and haven't had a chance to take a picture of them. I will do it first thing in the morning. If I had a sheet of the thick plastic they use I could probably work something out. I just dont have the time or space right now.
    I am really interested in that added insulation.
    If you dont mind me asking what is fatmax?
  10. Jul 24, 2009 at 8:01 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    similar to dynomat but cheaper, works good for insulation and sound deadening.
    Its fatmat not fatmax my bad. http://fatmat.com/
    What size of tire did you go with?
  11. Jul 24, 2009 at 8:10 PM
    Tacoyota
    08 4wd
    that nearly all black 5lug looks sharp jeremiekc, I've been tempted to paint my fenders red to match the body.
  12. Jul 24, 2009 at 8:13 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I see. I talked to the guy at Raamat (follow the link through the forum) he priced me a really great price to do the entire interior of the truck. It was going to cost like $250. I am also going to put more sound deadning on the firewall but havent figured out the logistics of it yet.
    The XRunner rim is 18 x 9.5 and has an off set the sets the edge of the tire even with the body. The tire that is recommended for it is a 255/40/18 and that is what I used. I also did not use the TPS's since the truck didn't have them when I bought it.
    I got the rims from an Xrunner guy in Houston for a really good price.
  13. Jul 24, 2009 at 8:16 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Thanks, I have a chrome grill and a chrome rear bumper that I put on it. I didnt like having all the different shades of black on it. I just ordered a new primered front bumper for it that I am going to paint BSP along with the mirrors.
  14. Jul 24, 2009 at 8:21 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    Cool I went with a little taller tire 235/55,
    $250 is a great price!
  15. Jul 24, 2009 at 8:28 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I was thinking of a taller one but I had to get what I could so that I can sell the old tires and rims so that I can get the tires that I want.
    I just wish that guy would post info on that TSB he got and the additional insulation. Free is better then anything.
  16. Jul 24, 2009 at 8:34 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    I think this is the one
    PDF attached
  17. Jul 24, 2009 at 8:35 PM
    Raven65
    Camden, SC
    I remember reading somewhere on here about a TSB related to rear-end/differential noise in some trucks. Toyota's "fix" was to install that sound insulation.
    <EDIT> Yep... that's the one epa4wd.
  18. Jul 24, 2009 at 8:36 PM
    Tacoyota
    08 4wd
    I suspect its an access or dc cab only tsb, i cant find one for us yet.
  19. Jul 24, 2009 at 8:49 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Well it is worth a shot to take it in. I spend alot of money at my local Toyota dealer so they are really cool about working on my truck and usually give me a discount on stuff.
  20. Jul 24, 2009 at 9:13 PM
    motoretro
    Michigan
    No, it was not 09 specific, in fact the TSB paperwork states 2005-08. My truck was built 6/08 and I assume the problem existed on early 09's also. The warranty info states "Install Rear Floor Silencer Pad & Sheet" & "R & R Rear Differential". The extra insulation is on the floor, not up the back of cab wall.
    Motoretro
