Release diff fluid for CV axle change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Labbi85, Sep 7, 2019.
  1. Sep 7, 2019 at 8:30 AM
    Labbi85
    Labbi85 [OP] Well-Known Member
    Quick Question. One of my CV boots leaks grease and because of this I want to change the axle and then replace the boot on the original axle.
    Now somewhere I read that I have to remove the diff fluid first but on a YouTube video I saw that they were replacing the axle without removing the fluid.
    Now do I have to remove the fluid first or can I leave it in?
    Thanks
  2. Sep 7, 2019 at 8:41 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Lift the side you are working on higher than the other. The fluid in differential is to the bottom of fill plug, to give you an idea how full it is. After you lift it the fluid will run away from high side of axle. Just leave that side higher till you're done. Repeat on other side.Use jack stands.
  3. Sep 7, 2019 at 11:33 AM
    Labbi85
    20190907_143506.jpg Thanks.
    Now I have a new question. How can I pop the the axle out of the diff housing?
    I know that it is only held in place by a snap ring and normally it should pop right out with a pry bar. Now I tried the prybar method in many different ways and it will just not come out.
    Did I maybe miss something? Or is the ARB diff locker maybe responsible for this?
  4. Sep 7, 2019 at 11:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You're on the right path, may just need a larger prybar. Pry, rotate a little, pry again, etc. Keep trying. If that doesn't work, you can make a makeshift slide hammer like I did in this video.
    https://www.youtube.com/watch?v=cVMuu5qJqVM&t
    TacoJoeBro likes this.
  5. Sep 7, 2019 at 11:41 AM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    Some are definitely tougher than others. I personally used a slide hammer to pull mine when I did ECGS bushing. I saw a video where a guy used some wire/cable to noose the CV, and gave it a hard yank. Worked for him. It might have been Tacomaholics ECGS bushing video on YouTube. The ARB locker shouldn't keep you from removing CV. But I'm not 100% on that.
  6. Sep 7, 2019 at 11:43 AM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    ^^^ He's quicker. That was the video I remember.
    EatSleepTacos likes this.
  7. Sep 7, 2019 at 11:44 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  8. Sep 7, 2019 at 12:31 PM
    Labbi85
    Great video going to try this approach tomorrow
    Thx
    TacoJoeBro and EatSleepTacos like this.
  9. Sep 8, 2019 at 1:13 PM
    Labbi85
    The method in the video worked great, took me maybe 6 or 7 pulls...thx again.
    Now I lost a little bit of fluid and was wondering if I can just top it of until the edge of the fill plug?
    I probably end up next weekend changing it anyway.
  10. Sep 8, 2019 at 1:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah you can certainly top it off, it’s such a minuscule amount of fluid that came out. Then just change and next necessary interval.
