Relentless Fab '05-11 Tacoma plate bumpers buy
Discussion in 'Relentless Fabrication' started by RelentlessFab, Jun 4, 2010.
  1. Sep 14, 2010 at 9:23 PM
    #341
    cmytacoma
    cmytacoma Well-Known Member
    Humboldt county NORCAL
    05 black DC LB sport
    Eclipse AVN 6620, Diamond audio 4.5" component in kicks, center channel with same mid and 2 tweets, infinity kappa perfect component 6.1 in front doors, kappa 6.1 coax in rear, sx900.4, fosgate power 1000, 06 L7 in ported box. BHLM, custom made sliders,
    thanks need to reblack out my lights and install my fogs into the bumper and fogs and horns behind my grill but shes getting there! this time im ready for Bambi!
  2. Sep 14, 2010 at 10:59 PM
    #342
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    As soon as I can afford to drop $600 for a spool gun setup for my welder :eek:
    Looks great man! :)
  3. Sep 16, 2010 at 2:30 PM
    #343
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Have you or Tim made, or considered making, a front plate bumper for the 2nd gen Tundra? I showed my fiend with an '07 Tundra pics of the bumper that Tim is building for me and he went nuts and wants one for his truck.
  4. Sep 16, 2010 at 3:29 PM
    #344
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    we would have to have a tundra in person for mounting and everything, so eventually it'll happen but we have a lot of tacoma's to take care of first haha
  5. Sep 17, 2010 at 8:07 PM
    #345
    RelentlessFab
    Eric
    Sparks, NV
    Hey man... its coming. :) I'm welding on the bumper now, I should have the welding on it done tomorrow, and hopefully have the sliders welded together as well. I'll pick up the Shackles too and PM you the remaining total. :cool:
    Yes, I will be building one! :) I've got a friend with an 08 Tundra so as soon as I can get my hands on his truck, I'll be able to build and sell them as well. Most likely around the end of the year. :D
  6. Sep 17, 2010 at 8:13 PM
    #346
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Hey, so did you need to weld something to my bumper or are they just bolt on items you were talking about? If so, I guess you can give them to Jason to give to me.
  7. Sep 17, 2010 at 10:44 PM
    #347
    RelentlessFab
    Eric
    Sparks, NV
    The frame braces are bolt on so I can give them to Jason. To install them you undo the 2 outside bumper mounting bolts, slip the brace plate over the studs, then tighten the nuts back down. After that, slip a 4" Grade8 bolt through: a reg washer-the frame brace plate-the hole through the frame-a 4" 'washer'-another reg washer, and then the nut and tighten it. You'll see what I mean when you get the plates and I'll also post pics of it all in the OP this weekend.
  8. Sep 20, 2010 at 11:45 AM
    #348
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    UPDATE: Picked up my Relentless bumper this morning from Fastenal and dropped it off at the powder coating shop. Construction looked VERY good. Stay tuned for pics and a review :)
  9. Sep 20, 2010 at 1:12 PM
    #349
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    Awesome! I can't wait to see more pics of the beautiful bumper! What color are you going to have it PC'd?
  10. Sep 20, 2010 at 2:52 PM
    #350
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  11. Sep 22, 2010 at 3:18 PM
    #351
    RelentlessFab
    Eric
    Sparks, NV
    Yeah I got it Larry. :)
  12. Sep 22, 2010 at 5:39 PM
    #352
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Here's a picture for people interested in what Relentless Fab's bumper looks like out fitted with a winch and fogs. Still debating a light hoop.
  13. Sep 22, 2010 at 6:30 PM
    #353
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    MOAR!!!!!!!!!!!!
  14. Sep 23, 2010 at 12:58 AM
    #354
    RelentlessFab
    Eric
    Sparks, NV
    Edited the order list... #13 bailed as he has sold his truck. All you guys later than that have been bumped up, an my50cal is now eligible for the drawing for the refund. :)
  15. Sep 23, 2010 at 3:34 AM
    #355
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    :yay:
    :bananadance:
    and thanks for the pics all.on.black :thumbsup:
  16. Sep 23, 2010 at 6:56 AM
    #356
    cohrmundt
    cohrmundt Well-Known Member
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    4.88 nitro gears, Detroit rear, Projector headlights, Relentless Fab custom bumpers and sliders, 6" Pro Comp suspension, all pro leafs, 37x13.5x17 toyo open country tires, method racing wheels, Flowmaster exhaust w/cutout, DTLT headers, K&N CAI, URD MAF calibrator, grillcraft grill with 30" and 20" led bars behind, windshield mounted 50" led bar, Infinity 6x9 speakers, Custom box w/MTX 7500 10"sub, MTX 1200 watt amp, blue led gauge cluster and radio mod, URD short shifter, fiberwerx fenders
    Looks bad ass! Now we want some pics of you using it:D
  17. Sep 23, 2010 at 7:05 AM
    #357
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Looks real good. Is there gonna be a matching rear bumper? Or is there already?.......searching
  18. Sep 23, 2010 at 9:13 AM
    #358
    all.on.black
    Auburn, WA
  19. Sep 23, 2010 at 9:33 AM
    #359
    cohrmundt
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
  20. Sep 23, 2010 at 10:16 AM
    #360
    RelentlessFab
    Eric
    Sparks, NV
    Gonna be working on it in a week or 2 since I have a stock rear bumper back on my truck and I cant handle it any more. My B-day is next week- might take the day off and work on the design a little then.
