Relentless Fab Tire Carrier Causing truck "bounce" on concrete highways
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kperatt09, Jan 4, 2019.
  1. Jan 4, 2019 at 6:47 AM
    kperatt09
    kperatt09 [OP] Well-Known Member
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    34's with all the fun attached
    Hey everyone! Just installed the relentless fab HC rear bumper on my 16' tacoma.. love the bumper and tire carrier, but, now when i drive on concrete highways my whole damn truck shakes/bounces. Didn't have this problem before the bumper. I have an ADS suspension kit.. ext resi's.. and dakars in the back. Running 33"'s.
  2. Jan 4, 2019 at 7:01 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Is the tire bouncing at all on the carrier? Having that much weight behind the rear axle can cause some unwanted bouncing if the tire carrier allows the tire to move around.
  3. Jan 4, 2019 at 7:04 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    the bed is fiberglass not much structural support
  4. Jan 4, 2019 at 7:08 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    His tire carrier is mounted to the frame, pretty sure there is some structure there.
  5. Jan 4, 2019 at 7:11 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    You stuck a whole bunch of weight further back. That change in weight distribution is going to upset the balance of the stock suspension. You probably need more shock and maybe more spring to compensate for it. Or if you have adjustable suspension, try that.
    Edit: Didn't read that you had suspension. Probably needs some adjustment.
    Gunshot-6A likes this.
  6. Jan 4, 2019 at 7:14 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Sounds similar to "porpoising," like what trailer towers experience. Weight added behind the rear axle creates that back-of-the-school-bus bounce. You probably need to stiffen up the rear springs.
    kperatt09[OP] likes this.
  7. Jan 4, 2019 at 7:18 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Wackyhacky and kperatt09[OP] like this.
  8. Jan 4, 2019 at 7:19 AM
    Woodrow F Call
    Colorful Colorado
    Oh, you might try changing the speed at which you are moving.... sometimes I hit a stretch of concrete and between the spacing of the joints and 60mph it gets a little bouncy (I guess it's the resonant frequency), I speed up or slow down and all is good.
    kgilly and JoeCOVA like this.
  9. Jan 4, 2019 at 8:12 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    No the swingout doesnt move at all. Pretty solid bumper and carrier...
    Sub_Par[QUOTED] likes this.
  10. Jan 4, 2019 at 8:13 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    I was thinking i probably need to either: A- screw with my shock valving, or B - add an add a leaf to my pack to stiffen them..
  11. Jan 4, 2019 at 8:15 AM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Are you running medium or heavy dakars
  12. Jan 4, 2019 at 8:15 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    Thank you! Would you recommend just going straight to replacing the hangers, or screw with the shocks first?
  13. Jan 4, 2019 at 8:16 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    it is around the same for me.. 60-70ish. Im just picky..
  14. Jan 4, 2019 at 8:16 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    i have the medium dakars
  15. Jan 4, 2019 at 8:19 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Screw with the shocks first to see if that can get you to a point where you're happy - that's free lol. I do think that the hangers were a very worth-while addition though.
    Yager78 likes this.
  16. Jan 4, 2019 at 8:22 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Seems to be common to body on frame vehicles, every truck I've driven does this to some degree. Not sure if there's a way to completely eliminate it.
  17. Jan 4, 2019 at 8:54 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    well sadly.. i was dumb enough to not get the compression adjusters.. so.. i have to ship them in to ADS.
    Did you just do the hangers, or did you do the crossbar too?
  18. Jan 4, 2019 at 9:01 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Ah ok - I assumed with ADS shocks you had the adjusters.
    I did get the crossbar but have not installed it yet. THere's some good info in the Archive thread. Most of the benefit comes from the hangers themselves and then a little extra rigidity comes from the crossbar.
  19. Jan 4, 2019 at 11:38 AM
    kperatt09
    Kaylor
    Denver Colorado
    2016 Tacoma OR
    #1regret, not getting adjusters for the rears.
    Ill start looking there then, thanks a bunch man. Do you have compression adjusters on your shocks? And did adjsuting them really make any difference?
  20. Jan 4, 2019 at 11:40 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    CanisLupus and Glueman like this.
