Relocating the Leaf Spring Shackles to shorten overall length.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pinoiako916, Jan 19, 2014.
  1. Jan 19, 2014 at 11:59 PM
    Indy
    Indy Master of all I survey.
    Which is 100% unrelated to the original question. A 4 link isnt a good first time with a welder project.
  2. Jan 20, 2014 at 3:09 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    shorten the springs? moving springs behind rear shocks ? Turn into flat bed ???? not really sure of what you want ??:notsure:
  3. Jan 20, 2014 at 9:08 AM
    Pinoiako916
    Pinoiako916 [OP] Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Or what about getting shorter rear leaf springs and then moving the rear leaf spring shackles forward to just behind the rear shocks? Will that work as well?
  4. Jan 20, 2014 at 9:13 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
  5. Jan 20, 2014 at 9:14 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    But why??? U just want a shorter truck? I kno im not really helping but just trying to understand wtf you're trying to accomplish by shortening your rear suspension...
    x2 Lol im so confused...
  6. Jan 20, 2014 at 9:14 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
    ^^THIS^^
  7. Jan 20, 2014 at 9:21 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No
    Only thing you can do to do what you described is 3 or 4 link.
    You can not just shorter the back half of a leaf spring and expect everything to work.
    im with Adam. You don't seem to understand how suspention works and are already digging yourself into a hole you are NOT ready to dig.
    Quit while your ahead. Do a LOT of research. Find a good reputable shop and have them do something for you.
  8. Jan 20, 2014 at 9:55 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    there would be pretty much no way to relocate the leaf spring mounts and use leaf springs w/o heavy modifications. you would have to do a link setup and even that would need heavy modifications. unless u have lots of welding experience & lots of suspension experience i would steer away from a project like this. i have little welding experience and would NEVER do any welding on my frame/suspension parts. it was stated earlier about bobbing the bed which is what i would lean towards if you are trying to shorten the overall length of your truck (not the wheel base..). The only thing involved in bobbing the bed is cutting & welding the back end of the bed together. you can get about 13" out of the very back end. thats about as much as you can get w/o shortening the wheel base (which requires cutting a chunk out of your frame and a custom drive shaft not to mention lots of welding.)
  9. Jan 20, 2014 at 11:30 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I read the first few posts of this thread last night, just got caught up this morning....
  10. Jan 20, 2014 at 11:32 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    check 45ACP's build. he cut his bed but I can't remember if he moved his shackles
  11. Jan 20, 2014 at 11:34 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    thats not what the op wants haha. he wants to make the back third of the leaf pack disappear, because apparently the "overhang" is bad
  12. Jan 20, 2014 at 11:37 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    whoops :eek:
  13. Jan 20, 2014 at 12:02 PM
    Indy
    Don't worry. This is one of those that would make more sense if we had Madden diagramming it on a whiteboard.
    Of course it would be the equivalent of Madden placing pre-schoolers on the line against pro NFL players.
    Which would make more sense.
  14. Jan 20, 2014 at 3:46 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Not sure if troll........... Or dumb............
