Remote Start: Good/Bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedneckHT07, Sep 22, 2008.
  1. Sep 23, 2008 at 4:27 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    if you do not want the alarm features you can get a remote start that will work off of your factory fob. typically you would have to press the lock button on the factory fob a few times in a sequence to begin the remote start functions. you will also lose a lot of range with the factory fob. my suggestion is to use the new remote which will allow you to remote start and lock and unlock your truck. the factory remote will stay active but you can put it in a drawer as a back up.
  2. Sep 23, 2008 at 6:20 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    yeah im good with that, it was just a thought, thanks for all the responses fellas
  3. Sep 23, 2008 at 9:03 PM
    Lunercrab
    Lunercrab Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    i didn't know you could have a remote start on a manual...does that mean you'd have to keep it out of gear when parked for it to work?
  4. Sep 24, 2008 at 12:11 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    yea the truck would have to be in neutral and the clutch start cancel engaged. Imo i wouldn't like not leaving it in gear but thats just me.
  5. Sep 24, 2008 at 3:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    So, there is a toyota factory installed remote start available?
    What's that run ya - ballpark figure - with installation?
    Does that also have a separate remote? Or can Toyota make it work with your current remote (or give you a new remote)?
    Thanks! Just coming up with more Christmast ideas....
  6. Sep 24, 2008 at 5:09 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    They make them for manuals, but it's a pain in the ass. You have to leave the truck running, get out, lock the doors, and turn off with the remote start. Or something like that so the system can verify the engine is running in neutral, but as soon as ANY of the doors are opened (oops! wife forgot something!) the system resets. Which means if you or your wife run out to grab something after you "set" the system, it won't remote start the next morning unless you do the set procedure again. At least, that's the ways systems work that the installers I've talked too would actually install due to liability issues. If I had that I'd probably stop using it within a week! :laugh:
  7. Sep 24, 2008 at 2:56 PM
    kwalton
    Baltimore, Md
    i just bypassed my clutch so i can always start it without engaging the pedal. i have had remote starts for years and have always driven a manual. i do have a switch which will disengage the starter if i am taking it in for service.
  8. Sep 24, 2008 at 6:03 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    so do you seriously have to get a new key with a remote start because they have to put some over ride in the ignition?
  9. Sep 24, 2008 at 6:17 PM
    kwalton
    Baltimore, Md
    most new cars come standard with a transponder based immobilizer system which basically means that there is a chip embedded in your key. i used the valet key and installed it in the bypass module (dei 556u) which will emulate a key in the ignition when you are remote starting
  10. Sep 24, 2008 at 11:50 PM
    Brian Price
    Brian Price Member
    Santa Barbara
    06 Tacoma 4.0L trd
    quick shift kit,magna flow,need some chips,headers,And a dang turbo!
    Just joined up. This is great all,the trd junkies in one spot
  11. Sep 25, 2008 at 5:01 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Only if you want it to work on a model with the engine immobilizer. :D
    They make models that emulate the key without using one I think, but those will be on higher end alarm systems.
  12. Sep 25, 2008 at 8:12 AM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    that sucks because its like 20 for a new key then 60 for them to program the damn thing
  13. Sep 25, 2008 at 9:08 AM
    piercedtiger
    Jon
    Southern Tier, NY
    My dealer wanted $45/key plus programming, and others have said $150 some places for the whole key/program package. So don't loose a key! :laugh:
  14. Sep 25, 2008 at 9:10 AM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    damn thats pretty bad
  15. Sep 25, 2008 at 9:24 AM
    #35
    piercedtiger
    Jon
    Southern Tier, NY
    yeah. I normally have 3-4 spares for my cars. Me, wife, mother, one hanging in the house.... Just in case. Not at the price of these!! I might just have it copied to a blank so I can at least open the doors if I lock the transponder one in the cab.
    hell, blanks from Wally World might work too if you already have the transponder key close enough for the remote start to work....
  16. Feb 11, 2019 at 7:12 AM
    #36
    PerryTaco
    PerryTaco Member
    Dave
    Central PA
    2019 DCSB Sport MT6 in Cement
    bed mat, raised black letters in the tailgate, debadged the V6 badge, added the Hondo garage vent phone mount, glove box, console and tray organizers.
    How did you do that? I was searching and your post was the first one I came across
    PennSilverTaco likes this.
  17. Feb 11, 2019 at 8:13 AM
    #37
    piercedtiger
    Jon
    Southern Tier, NY
    I did this on my Corolla by unplugging the switch under the clutch and jumping the pins with a piece of wire. I don't have a Tacoma anymore, so I'm just guessing something similar would work.
    PerryTaco[QUOTED] likes this.
  18. Feb 11, 2019 at 10:24 AM
    #38
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I have a Clifford 2 way remote start. Amazing range and you get confirmation that it received your input or if the alarm is going off.
    Great for defrosting the windows in the winter or some A/C in the summer.
  19. Feb 11, 2019 at 10:35 AM
    #39
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've got a Viper Smart Start with GPS and really like it . As long as I've got a cellphone signal the range is Unlimited . Last year I was able to start my truck and unlock the doors from over 2600 miles away
  20. Feb 11, 2019 at 2:45 PM
    #40
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bet it was warm when you got there.
