Remote start - how to get in without shutting off engine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by robfrye, Apr 25, 2021.
  1. Apr 27, 2021 at 5:51 AM
    #41
    robi0024
    robi0024 Well-Known Member
    WA
    21 Double Cab TRD Off-Road
    My remote start wasn’t working so I ended up calling Toyota and they sent me over to some tech support and reset the account tied to my truck remotely. Then the remote start worked. Might be worth a call to put the ball in their court. If I’ve got key fob remote start on a TRD OR then it’s likely you have it in the Pro.
  2. Apr 27, 2021 at 7:25 AM
    #42
    Uscolt45
    Uscolt45 Member
    Bryan
    Denver
    2021 TRD Pro Mag Gray
    Thanks, I’ll try that later. It’s not a big deal since I will use the app, just making me scratch my head. Plus if my wife uses it or I borrow it out I’d like it to work.
  3. Apr 27, 2021 at 5:07 PM
    #43
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    How about installing a remote start on a 2016 Tacoma, anyone have any idea? I bought one online a few years ago and couldn’t ever get it to work, I would program it correctly, it would flash as it should. Then when I would try to start it all it would do is run the fuel pump and that’s it..... The company even sent me another control module for the remote start, assuming it was the issue. That did nothing either and I eventually just gave up on the idea completely.
    I believe it’s a “Fortin Evo” unit.
  4. Apr 27, 2021 at 5:22 PM
    #44
    arrakis429
    arrakis429 Waiting for the Mets to repeat 1986
    Ben
    Springfield, OR
    2016 Quicksand TRD Sport ACLB 3.5L 6MT (OVTuned)
    Fuel Mavericks w/ Falken Wildpeak AT3W 285/70/17 (Soon to be SCS Ray 10 w/ Falken Wildpeark AT4W 255/80/17) Leer 100 Topper + Prinsu Cabrack Cali raised Bed stiffeners RCI Sliders RCI skids Bilstein 6112 Front 5/4 w/ Eibach 700lb Coils SPC LR UCA's Bilstein 5160 Rear OME Dakar HD Leafs Wheeler's UBolt Flip w/ Bumpstops N2 Designs MT remote starter OVTuned ARB Awning w/ Windbreak and Deluxe 'Room' SpartanXCustoms Amber Scoop light Pelfreybilt Aluminum Front Plate Bumper w/ CaliRaised 32” light bar and Baja Designs Amber Squadrons Wide Cornering Warn Zeon 10s Platinum Winch 2Lo Mod URD Stage 3 Clutch with Heavy flywheel Accumulator delete mod TacoGarage Dash Multimount Warfab Phantom Rear Bumper OVTune Dump tubes
    I second @VB25 . I've got the basic N2 remote starter, no frills, on an MT, and I can open the door, slide the key in, and get moving. Alternatively, the truck will stay on for a bit when I take the key out and only shuts off when (after the key is removed) all the doors are shut. This means If I need my key for something, say the tailgate because I forgot something back there I can set the remote start sequence, remove the key, truck stays on, go fetch whatever from the bed, and put the key back in and get going to wherever. I haven't tried to run the power outlet in the back without the key in yet - but none of the other accessories stay on(radio turns off, etc) when I remove the key so not sure if that would work.
    I love my N2 and use it on the daily. It is so convenient. There is even a valet setting but I don't remember how to set it
    N2DesignsInc likes this.
  5. Apr 29, 2021 at 3:00 PM
    #45
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    This only affects all Toyota and Lexus Push to Start. Not Key, HKEY, GKEY or Std. KEY
  6. May 4, 2021 at 10:53 PM
    #46
    dennguy08
    dennguy08 Well-Known Member
    2018 Cement Tacoma TRD OR
    Had no idea they even had remote start on the 3rd gens...
  7. Jan 31, 2022 at 7:16 PM
    #47
    gwilly440
    gwilly440 New Member
    2022 Off Road
    I found this odd as well. My 2015 Jeep Grand Cherokee had factory remote start and it would not shut off when you opened the door. The system required you to push the start/stop button with the key fob in the vehicle before you could press the brake or shift into gear. It is obviously possible and I find it strange so many manufacturer’s can’t offer it. I used my remote start for my Tacoma in -20F temps the other day and when I got in it wouldn’t start again. I let it sit for a few minutes the tried again and it barely started and smelled of fuel badly in the cabin. I have a ‘22 with 1000 miles on it!
  8. Jan 31, 2022 at 8:44 PM
    #48
    N2DesignsInc
    Los Angeles, CA
    That's why batteries are rated by Cold-Crank-Amperage (CCA) which is typically higher than what the load when temperature is nominal, ideal and alternator charged via driving. This is because the cold plays a role in a battery's performance. Cold weather degrades it by 30-60%. That's huge. That's why is something needs 200A to run, you size it in theory based on start up load or demand since that's spike for a second until the vehicle is running and being driven will kill an incorrectly size battery quickly and viscously and the first engine crank that fails, will take away some more of it's ability to start...until it's time for a jump or charge. A battery should never be drained to that extent. It will need to be recharged and calibrated...but I assure you, it won't be the same ever again and you'll live in fear of it dying anywhere anytime again for the time it took you to load groceries with the door open.
    Toyota undersized the OEM batteries. They suck from the get go and don't last too long with normal use...and they know it or else they would deny remedies for re-charge or swap out due to it being a "wear n tear" part.
  9. Feb 1, 2022 at 4:49 AM
    #49
    BanjoBen
    BanjoBen Well-Known Member
    2021 DCLB TRD Sport
    Our 2016 Nissan Murano doesn’t shut off either. I love the truck, but that has been one annoying “feature.”
  10. Feb 1, 2022 at 5:30 AM
    #50
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    The timing of the lock-lock-lock sequence is extremely finicky. You probably haven't gotten it "just right" yet. And even after you figure it out, it's still a PITA. Always takes me a couple of tries.
    Russ68 likes this.
  11. Feb 1, 2022 at 6:25 AM
    #51
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I have experienced this also with my 2018 with a remote start. In really cold temps if I start it, let it run 15 minutes, then go out 5 minutes later to just listen to it sputter a few times then start. Its almost as if when the remote start shuts off, fuel still flows into the engine and floods it.
  12. Jul 27, 2022 at 10:48 PM
    #52
    Lithium177
    Lithium177 Member
    I know this is a old post and many if not every site I've searched says it can't be worked around. My question is is the shut off initiated by the marker light blink when you open the car? I know most aftermatket units use the brake light as a shutdown signal. Is there no one that could read a wiring diagram on the remote start to determine what makes the computer shut off? Once we know the signal should be able to bypass it or redirect it.
    VB25 likes this.
  13. Jul 27, 2022 at 11:31 PM
    #53
    808army
    808army Well-Known Member
    hawaii
    17 offroad
    buy manual trans u want bypass it
  14. Jul 28, 2022 at 1:28 AM
    #54
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not to my knowledge since you can lock and unlock the door without issue and there's no way to activate the brake lights before the truck would have shut off anyway. The only real workaround is having a version with a keyed ignition such as a lower trim level or manual transmission.
  15. Jul 28, 2022 at 12:44 PM
    #55
    Lithium177
    Lithium177 Member
    I own a manual trans and as soon as I unlock the truck it shuts off
    SaulGoodman likes this.
  16. Jul 28, 2022 at 4:12 PM
    #56
    808army
    hawaii
    17 offroad
    i dont have that problem with mine.
  17. Jul 28, 2022 at 11:25 PM
    #57
    republic_of_texas
    republic_of_texas Well-Known Member
    Josh
    Austin TX
    Black 2016 Tacoma TRD Sport 4x4
    3/10/22 •icon stand 9 suspension with billet UCA’s, running medium duty Dakar leafs •method NV on 32” BFKO2 •Prinsu RR with Cali raised dual function LB •DIY BHLM •BANTAMMAX8 and SPOD •arb single comp •KC FLEX ditchlights •Wescot designs rock sliders •Relentless Fab HC rear bumper with spod •BA slimline front bumper with 20” lb, 11K lbs Superwinch •full RCI skids •MobTown fab BR, with rotopax and traction board mounts •softopper •OVTUNE dump tubes •AFE COI •URD spec u y pipe and full exhaust •KDMAX pro Tune •Smitty bolt RTT, and canopy •TBC
    I have the same issue
  18. Dec 12, 2022 at 5:42 PM
    #58
    North705
    North705 Well-Known Member
    Jay
    Durham Region, Ontario, Canada
    2023 TACOMA 4X4 TRD OFF ROAD ACCESS CAB 6A - Blue Crush Metallic
    Front Grille - to a TRD Pro Grille TRUXEDO PRO X15 - Tonneau Cover Debadging (going for a full chrome delete) Color matched Recovery Ring Trailer Hitch Front Tow Hooks Color Matched DV8 Offroad Bumper Center Mount (currently a work in progress)
    I bought a 2023 and was hoping this was addressed and fixed .. found a 7 month old video basically saying toyota was aware this was annoying and was going to address it .. well I guess mine isn't the 'selected model' they referred to .. I honestly hate that the engine shuts off just so you can start it back up again a second later
    https://youtu.be/Uj-btCXdasY
  19. Jan 19, 2023 at 8:39 PM
    #59
    sarahsunshine8788
    sarahsunshine8788 Member
    Sarah
    2021 Tacoma 4X4 off-road TRD access cab
    press the lock button three times and hold the lock button on the third press until your lights flash 5 times then let go. Took me a few times to figure it out too now I count how many times the lights flash after I press lock twice and hold the third press.
  20. Jan 19, 2023 at 8:45 PM
    #60
    sarahsunshine8788
    Sarah
    Also I recently upgraded from an 09’ taco to a 2021 and can’t figure out how to update my profile so disregard the fact that my profile says I am an 09’ tacoma TRD owner.
