Remote Start with Manual trans
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zims23, May 16, 2017.
  1. Nov 26, 2017 at 5:23 PM
    Woodsan
    Woodsan Member
    2017 Tacoma DCSB TRD Off-Road
    @bodean, which system did you go with? That arming sequence sounds much more manageable compared to the Viper.
  2. Nov 26, 2017 at 7:31 PM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    I'll also second Compustar, same sequence I've used to set it on a previous vehicle. Just make sure to keep your parking brake in tune over the years
  3. Nov 26, 2017 at 8:05 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Something else to consider. Toyota does not want you to add a remote start unless it's a Toyota remote which isn't offered for the manual. If you install one your pretty much on your own as far as warranty is concerned. They pretty much tell you to remove it and return it to stock. This would require a new wiring harness because they don't want any alterations to the data lines.
  4. Nov 26, 2017 at 8:17 PM
    Misfit
    Misfit Well-Known Member
    IL
    2017 SR 2.7L 4x4 5MT
    Please elaborate on this, was this just from your dealer or someone actually knowledgeable on the topic?
    I'm sure you're aware of the Magnuson-Moss Warranty Act, simply having aftermarket accessories is not reason for Warranty claim denial.
  5. Nov 26, 2017 at 8:23 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Right from Toyota. This has nothing to with warranty denial because of aftermarket parts . Your adding an aftermarket device that Toyota isn't going to be responsible for. When you phone the tech line for support they are now asking if the vehicle has a aftermarket remote.
    Just to add, they won't deny you warranty, you just have to bring the vehicle back to stock. Because the aftermarket remote taps into the data lines Toyota consider them altered and will make you repair them which means a new wiring harness. Toyota's remote which is now available for the auto Tacoma is an add on controller that doesn't require damaging any wiring harnesses. It's activated using the techstream and is just like any other module in the vehicle.
  6. Nov 28, 2017 at 5:09 PM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
  7. Nov 28, 2017 at 5:27 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    What does third party through Toyota mean? If your dealer sends the vehicle out to have the remote start put in it's still will void your warranty through Toyota corporate.
  8. Feb 7, 2018 at 12:14 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    So happy they still make these in manual. After switching over from auto I don't think I'll ever go back
  9. Feb 7, 2018 at 8:11 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Does anyone make T harnesses for the manual trans Tacomas? Think I would go with the compustart?
  10. Feb 7, 2018 at 8:15 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Think about all the electrical systems that need to be tapped into to make that work properly. Not the kind of headache I want if something starts going wrong.
    And in the end, you're still parking your truck in NEUTRAL which is bad practice since you're relying on the E-brake and nothing else to prevent the truck from rolling.
    I believe remote starts in manual transmissions are dumb.
  11. Feb 7, 2018 at 8:23 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Obviously you don't live on a cold climate. It was -35C this morning at my location.
    Intrepid likes this.
  12. Feb 7, 2018 at 8:30 AM
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    This sounds more inline to what I had in a previous car...
    If I recall correctly Audio Shop had customized a PAC-AUDIO Trigger Module to bypass the Directed Electronics sequence (back in 2004)...
    Only issue I had one time is that I forgot to leave car in Neutral and pressed the wrong buttons (wanted to roll windows down) on the Remote and AutoStarted car... Realized what I had done, and had to run to car while it was cranking engine, and pushing another car forward... *whoopsies* lol...
  13. Feb 7, 2018 at 8:56 AM
    Cold_Toad
    Cold_Toad Well-Known Member
    The clutch cancel button does not care if the truck is in gear or neutral it will engage the starter regardless, that button was actually made for starting the truck with it in gear.
    I don't believe the truck actually has any way of telling if the transmission is in neutral or in gear.
  14. Feb 7, 2018 at 9:25 AM
    Cold_Toad
    Wait, did you just post telling yourself not to do something?
  15. Feb 14, 2019 at 9:38 AM
    #35
    DenverTaco
    DenverTaco Member
    Connor
    Denver, CO
    2019 TRD-Offroad Cement DCSB 6MT
    Extang Soild Fold 2.0 Tonnueau Cover Hondo Radio Knobs Mud Flaps Center Consol Organizer Window Tint
    I have a 2019 TRD Off Road DCSB 6M transmission. I went back to the dealership to have the stock remote start activated. I waited a week for the dealership to come to my house only to find out that I cannot have this option installed because of the manual transmission. I’m baffled that the dealership even took my money and sent out a technition knowing damn well that this wouldn’t work.
    Has anyone figured out a solution for this? I looked at the plug n play and from the looks of it I can use the Tacoma’s key.
  16. Feb 14, 2019 at 10:08 AM
    #36
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    https://www.n2designsinc.com/produc...a-plug-and-play-remote-start-kit-h-key-manual
    N2DesignsInc likes this.
  17. Feb 14, 2019 at 11:41 AM
    #37
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
  18. Feb 14, 2019 at 11:47 AM
    #38
    90ToyAllTrac
    90ToyAllTrac Member
    I got a viper few weeks ago. Compustar also makes for MT. All I have to do is stop, neutral, brake, parking brake, release brake, everything blinks a-ok, pull out key, get out, close door and shuts itself off in 15 seconds. It's pretty slick.
  19. Feb 14, 2019 at 11:50 AM
    #39
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    It 100% can be done, look into @N2DesignsInc, he's been a great help and responds quickly to any questions you might have.
    N2DesignsInc and Roddy13 like this.
  20. Feb 14, 2019 at 11:51 AM
    #40
    Roddy13
    Roddy13 Well-Known Member
    +1 for N2Designs 100% plug and play for Manual Trans
