Remote start?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Dec 1, 2010.
  1. Dec 1, 2010 at 5:01 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    Where can i find one? is it easy to install?
  2. Dec 1, 2010 at 6:08 PM
    jjsask
    jjsask Well-Known Member
    Regina, Saskatchewan, Canada
    2002 XtraCab 4x4 TRD
    I find the best places are local car audio and accessory shops. Here in Canada anywhere that sells anything for cars will sell them but I don't know about your area. You could always buy one online.
    What features are you looking for?
    Alarm, 2-Way, Paging. If you let me know what you want I can help you pick one out.
    They are by no means a plug and play install. Depending on what features you have you are looking at tapping into about 20 different vehicle circuits, running your wires neatly to the control module, finding a place to secure the module under the dash, and then programming the unit (that's the easy part). If you are comfortable soldering and you have a good understanding of 12 volt electronics it is a great project that will save you about $200 on the install. One note is that 1st gens don't have any anti-theft transponders built into the keys which makes the install much easier than in newer models.
    I have installed many of these units, including one in my 2002 Tacoma and would be happy to answer any questions you have.
  3. Dec 1, 2010 at 7:32 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I'de be afraid of deploying the air bag, too many wires for me.
  4. Dec 1, 2010 at 8:09 PM
    sir1123
    Charleston
    i have a viper remote lock system and on the remote it has an auxilary button so i guess i can program it to do anything?
  5. Dec 1, 2010 at 9:09 PM
    jjsask
    All airbag wiring connectors are bright yellow and the wire usually runs in yellow wire loom. As long as you never attempt to test any yellow connectors there will be no issues. Also using a digital multimeter is much safer for testing than a test light as the current flow is many times less through the multimeter.
    What is the model number of your remote lock system? You won't be able to program the auxilary button to do a remote start unless the remote lock system has a starter module built in. If you want to add a remote starter you would likely remove a keyless entry system first as most all remote starters also control door locks. Usually those auxilary buttons would get connected to a relay and control something like fog lights.
  6. Dec 1, 2010 at 9:13 PM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    best buy has 2 way starters with install for $300. (in canada)
    hoping to get this for christmas.
  7. Dec 1, 2010 at 9:29 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    This reminded me of the time I put remote start in my mothers bronco. Well the thing was she drives a standard at work. Well she came in one night and killed the bronco and left it in drive.
    The next morning I hear her remotely start it. The next thing I know the bronco is in the dining room with me!
    Moral of the story, make sure you don't bypass the ignition kill switch for the gear selector.
