Remote Start
Discussion in '1st Gen. Tacomas (1995-2004)' started by stucksucksnayota, Nov 18, 2007.
  1. Nov 18, 2007 at 4:36 PM
    stucksucksnayota
    stucksucksnayota [OP] Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I recently ordered and tried to install and Bulldog Deluxe 500 remote start and keyless entry on my 01 taco and i was wondering if anyone has put one of these things on before.
    Everything works but it will not start the truck it will turn it on and the parking lights will flash but the engine does not turn over and start up
    Any ideas????????????
  2. Nov 18, 2007 at 6:01 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    No positive but does your truck have a computer chip in the key like the 05-current trucks do?
    If so without that chip the truck would not start...just crank over.
    (if thats the hang up I am sure there is a bypass somewhere.) Call the manufacture and ask tech support.
  3. Nov 18, 2007 at 7:52 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    or if the truck is a clutch you have to bypass the clutch start button on the dash
  4. Nov 19, 2007 at 7:06 AM
    stucksucksnayota
    Barry
    i dont think my trucks key has a chip in it but i will check on it.
    It is an automatic so there is no need for the clutch start button
    thanks for the help
  5. Nov 19, 2007 at 7:42 AM
    stucksucksnayota
    Barry
    Well I just read on the companies website that it will do what my truck is doing if it has an anti theft system on it and im pretty sure mine does.
    Can i just cut that antitheft box out or is there something speical i need to do to turn it off??
  6. Apr 22, 2008 at 5:13 PM
    installersam
    installersam Well-Known Member
    raleigh NC
    03 Double Cab
    That truck should not have a chip in the key, nor should it have a antitheft system. There are a couple of things that could keep it from turning over. Does the bulldog have a neutral safty wire? Most remote starts do, if so that wire needs to be grounded. Also if you have a acc. wire tied into a ignition wire the truck will not start. the ignition wire should be 12v during start up, the acc. wire goes to 0v during start up. I am not familiar with the bulldog units, i install Viper systems, but they should be very similar. If you need wiring info for the truck i can get that for you. did you hook up a hood pin?
