Remote tailgate lock connected to aftermarket alarm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob_s, Aug 14, 2010.
  1. Aug 14, 2010 at 4:08 AM
    rob_s
    rob_s [OP] Well-Known Member
    SE FL
    White 2010 DC SB Sport
    Anyone gotten this done or worked out? Seems like the button for the trunk release on a car could be made to work with something like the Dynolock or the Pop & Lock.
    Alarm in question, if it matters, is the Viper 5901.
  2. Aug 14, 2010 at 4:46 AM
    H0LLYW00D
    H0LLYW00D Well-Known Member
    My 5901 has the shock sensor set on high and it will go off if you were to open the tailgate with force. Even closing a door after the system is armed sets of my alarm, but then again so does a bunch of motorcycles riding by too. Hope this helps.
  3. Aug 14, 2010 at 4:55 AM
    rob_s
    SE FL
    I would assume that hitting the tailgate button would have to disengage the shock sensor as well, just like it would in a car for opening and closing the trunk.
  4. Aug 14, 2010 at 7:08 AM
    H0LLYW00D
    The only way for me to unlock the tailgate is the door unlock which disarms the system.
  5. Aug 14, 2010 at 7:19 AM
    rob_s
    SE FL
    so you do have the alarm connected to a tailgate lock though? It just opens with the doors instead of separately?
  6. Aug 14, 2010 at 7:48 AM
    H0LLYW00D
    The door operates the tailgate lock. Did t have to add anything to the alarm as it already could sense shock to the tailgate
  7. Aug 14, 2010 at 7:51 AM
    rob_s
    SE FL
    What sequence did you install everything? Do it yourself or have it done?
    I'm thinking of picking up the Dynolock and installing the hardware myself but leaving the control wire trailing, and then having the alarm installer connect the wire(s) to the alarm and hopefully be able to isolate the tailgate away from the doors as if it was a trunk.
    What I'm hoping to do later is add a hard tonneau or a shell with a remote-unlock and have that tied in as well so that I can access the bed without unlocking the cab, and vice-versa.
  8. Aug 14, 2010 at 8:05 AM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    You could add a door pin switch on the tailgate, bedcover, whatever, and add it to the alarm.
  9. Aug 14, 2010 at 9:21 AM
    H0LLYW00D
    I thought of having the trunk switch open the tailgate. I'll let you know how it goes. The alarm came with the truck and I added the power lock for the tailgate
  10. Aug 14, 2010 at 10:35 AM
    joes06tacoma
    Joe
    Central Coast, CA
    www.[B]the12volt[/B].com/
    Lots of relay wiring info on this site. I'm sure it can be done, just going to take a little time puzzling it out.
