Removable Storage Box for Truck Bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Mar 13, 2014.
  1. Mar 13, 2014 at 3:09 AM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Any recommendations for large, heavy duty plastic/ABS, removable storage boxes that are lockable and can be secured to the bed with a cable lock or chain?
  2. Mar 13, 2014 at 3:12 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Rubbermaid Action Packer Containers
  3. Mar 13, 2014 at 4:05 AM
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    Contico Xtreme Tuff box. Has a key lock + additional padlock capability if you are storing expensive items. I just use it for files/brochures/samples, so not that concerned about the padlocks. Bolted to the bedrail, and I added the gas struts.
  4. Mar 13, 2014 at 4:14 AM
    nyfishhunter
    nyfishhunter Well-Known Member
    Sean
    White Plains, NY
    2010 DC 4x4 OR Pyrite
    Weathertechs, Pop N Lock, Whitetail Sockmonkey, OEM bed mat, Undercover SE, Wet Okoles, OEM iPod interface, Rear Spring TSB, Illuminated 4x4 switch, DTRL, Timbrens, 5100s (front .85), Eibachs, 1.5 AAL, OEM running boards, FJ TRD center caps, diff breather mod, trimmed front flaps, ImMrYo mirror bracket, Grillcraft, painted white Sport grill black
