Remove and replace your scratched up instrument cluster plexiglass
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blazingbluesport, Jul 30, 2017.
  1. Jun 21, 2024 at 5:28 PM
    #641
    jkisf
    jkisf Well-Known Member
    JK
    Koreatown Los Angeles
    Stick Shift TRD Pro
    Dont go commando on it next time when cleaning it.
    TacoTime55 likes this.
  2. Jun 21, 2024 at 6:19 PM
    #642
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    That plastic scratches if you look at it the wrong way. Nothing to do with going ham
    Taco Egghead and JmsWms like this.
  3. Jun 23, 2024 at 6:37 AM
    #643
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
  4. Jun 23, 2024 at 10:02 PM
    #644
    MGMDesertTaco
    How long did it take for any bubbles under the film to dissipate? I might re-order. :rolleyes:
  5. Jun 23, 2024 at 11:10 PM
    #645
    musicisevil
    Alaska
    2019 TRD Sport
    Day or two at most. In the summer heat they should be gone quick. I have a dirt particle trapped under mine, but haven’t ever gotten around to redoing it :frusty:
    You didn’t splurge for the backup film?
    MGMDesertTaco[QUOTED] likes this.
  6. Jun 24, 2024 at 12:20 AM
    #646
    MGMDesertTaco
    No, but I thought about. I wonder if it would be easier to apply with the cluster removed? :notsure:
    I might try and peel it up and redo. Worst case I'll replace it.
    edit: My issue was more with the included soap/water bottle. Like the soap solution didn't mix up properly and dried in pools under the film.
    I tried peeling it back and reapplying with sprayway glass cleaner, but it appears the soap and or my fingerprints have fused themselves to the bottom of the film.
    musicisevil[QUOTED] likes this.
  7. Jun 24, 2024 at 1:00 AM
    #647
    MGMDesertTaco
    New film ordered, 2 sets this time. Maybe I'll order another cluster too.:rofl:
    musicisevil likes this.
  8. Jul 6, 2024 at 9:10 AM
    #648
    Nordicbeast
    Nordicbeast I wanna be sedated...
    '23 TRD Pro 6MT
    I *just* installed the Protech kit on my 9 month old Pro this morning...I'm pretty meticulous when I clean but the IC glass is scratched to sh!t. Should've ordered a new one prior to installing the Protech...which is quite hazy after installing but apparently clears up in a few days....we'll see. May still get a replacement IC glass and use my spare Protech film in the new one. Removing the nav/IC bezels is a MUST prior to installing the film.
    Canadian Caber and BBogey like this.
  9. Jul 7, 2024 at 4:12 PM
    #649
    Nordicbeast
    '23 TRD Pro 6MT
    ^Follow up....haziness cleared in 1 day....there's one air bubble, hopefully that will clear soon. Overall very happy! Now what to do the the spare set of film that I ordered! Lol
    Canadian Caber and JmsWms like this.
  10. Jul 8, 2024 at 2:58 AM
    #650
    Xbowguy
    Xbowguy Well-Known Member
    Jeff
    Pa
    2023 Tacoma 4x4 SR5 double Cab Barcelona Red
    sell it on here. I’m sure there’s others out there who hate scratching.
    Nordicbeast[QUOTED] likes this.
  11. Jul 9, 2024 at 8:52 AM
    #651
    crockett8513
    crockett8513 Member
    Huh. Didn't even know it was a separate piece
  12. Jul 15, 2024 at 10:23 AM
    #652
    Andretti
    Andretti Active Member
    Kansas City, Missouri
    2023 Tacoma TRD Sport, 2008 Shelby GT500
    I traded in my 2009 Tacoma last week and came home with a black 2023 Tacoma Sport. The radio it came with does not have the Navigation nor Car play capabilities.
    While looking around tacomaworld in the few days since my purchase, I noticed many felt the need to put a screen protector on the gauge cluster as well as radio of their 3rd gens to avoid scratches, so I decided I probably should do so as well.
    That all being said, I just wanted to confirm I'm measuring the screen size correctly on the stock radio so I then order the correct screen protection kit. I'm a bit confused since when I choose the 8" screen size (If I measured correctly), the description does include the Sport models, but also lists Nav as well. Since mine is without, I figured I'd be more likely to get the correct set if I posted so I could be sure I'm not somehow messing this up.
    I took a pic of my radio showing where I measured to confirm I have properly measured.
    my measurement locations
    website showing how it lists it
    I'm probably guilty of way over complicating this, but I'm pretty bad OCD at times so my apologies in advance
    Thanks in advance for the help
  13. Jul 15, 2024 at 10:58 AM
    #653
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    The 23 OR ProTech kit fit my 23 OR with nav and JBL. Not sure about the measurements but here is a ref pic of the kit which did fit correctly.
    Andretti likes this.
  14. Jul 15, 2024 at 11:03 AM
    #654
    BBogey
    BBogey Well-Known Member
    2003 Tundra, 2012 Tundra and now a 2023 Tacoma
    I think you’ve got it right. Not sure if your radio is different than mine, size wise (I have a 2023 sport with nav and car play) so I think you’re good. I am curious how you got it for $54 and I think mine was $84 with tax/shipping.
    LOL, got mine delivered 10 days ago, but between 100 degree days, and me being scared to screw it up, well, I just haven’t tried to install it yet
  15. Jul 15, 2024 at 11:22 AM
    #655
    Andretti
    I’m sure my total will be higher and much closer if not ultimately higher than your order. The number showing is just the initial selection. I will also be adding a second kit considering the likelihood I will screw up on my initial attempt. Plus tax and shipping will also be added.
    thanks for the responses. Makes me feel more comfortable I have selected the set I actually need to fit
    BBogey[QUOTED] likes this.
  16. Dec 30, 2024 at 7:21 PM
    #656
    cedy01
    cedy01 Active Member
    Cedric
    Vancouver
    2016 Black Tacoma TRD Sport
    3" bilstein lift 33" tires SCS rims off-road lights TRD pro grille & amber lights cali raised rock slider +more to come
    Just noticed how scratched mine was when cleaning it the other day. Has anybody found a way to clean it without scratching it to shit or is replacing the plexi + a screen protector the way to go
  17. Dec 30, 2024 at 7:22 PM
    #657
    MGMDesertTaco
    The screen protector is the only way imo. It scratches if it gets breathed on wrong.
    You might order 2 screen protectors. Try one on the scratched plexiglass to see if it minimizes the damaged look.
    Canadian Caber and musicisevil like this.
  18. Feb 7, 2025 at 8:22 AM
    #658
    Renegade50
    Renegade50 Well-Known Member
    Clarksville, Tn
    2025 Black SR 4wd
    Tag for future reference
  19. Mar 9, 2025 at 4:42 PM
    #659
    sulaco83
    sulaco83 Member
    23 TRD OR Manual
    I just replaced my lens. Pretty easy as long as you don't drop a screw down into the dash like I did :(. Also word of caution that the white plastic clip on the harness is super brittle or at least mine was and it snapped off without much pressure. Hopefully it's not a big deal to live without. Has anyone else broken that clip? Did you replace it or leave it broken?
  20. Mar 23, 2025 at 7:24 AM
    #660
    Renegade50
    Clarksville, Tn
    2025 Black SR 4wd
    Why didn't Toyota just make the instrament cluster cover out of the same plastic as the head lights.
    That is the mystery.
    What???
    Add like 10 or 20 bucks on the price of a new vehicle.
    Probably a issue across many of their models
    Or offer ones that don't scratch all up... charge a 20 30 buck replacement/ install fee at dealership as some sort of recall/ fix.
    Wouldn't be a issue to me at least.
    Not on a special kitty pate and soda cracker penny pinching eckking out a existence meal plan.
    bmg88201 and BBogey like this.
