Remove the differential drop on your 05+ Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mjp2, Oct 15, 2010.
  1. Mar 2, 2014 at 8:15 AM
    #221
    rcrick263
    rcrick263 Well-Known Member
    Utah
    06 TRD Off Road 6spd
    None
    Yeah I've had airbags on 2 of my other trucks. 01 gmc 2500 4x4, 03 gmc 1500 4x4, And I have them on my work Truck (2012 F-150 4x4) They are nice if you are carrying heavier loads you can adjust for it.
    Taco Lean
    http://www.tacomaworld.com/forum/1st-gen-tacomas/9931-taco-lean.html
  2. Mar 2, 2014 at 8:39 AM
    #222
    rcrick263
    Utah
    None
    Are you running the full 3" of lift with your OME kit?
    I'm from Planet "I don't know anything about suspension" haha. So Icon sells all the parts you would need for a rebuild? And i could easily do it myself?
  3. Mar 2, 2014 at 10:32 AM
    #223
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah I am.. I have the 885's with a 1/4" top plate spacer for a full 3" lift. plus the trim packer spacer on the drivers side for the lean.
  4. Mar 9, 2014 at 9:17 PM
    #224
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Alright Gents...
    After a thorough examination of the evidence, I have decided to forgo the "DD" spacers from my 3" lift. Can someone tell me the correct bolt (x2) that is OEM after I remove the spacers to get it back to stock?
    The guys who did the lift install kept the parts removed and I didn't think about it at the time... That was awhile ago, so those parts are MIA...
  5. Mar 9, 2014 at 9:59 PM
    #225
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Should be able to use the bolts that are in there now if there's enough thread... Can't remember
  6. Mar 9, 2014 at 10:10 PM
    #226
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Rgr...I know they would work, but they're over an 1 1/2" in length. Guess I could cut'em down and still use them and save the cash though.:cool:
  7. Mar 9, 2014 at 10:13 PM
    #227
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    That pic reminds me of seeing a turtle on it's back! I can't bare to see it suffer!...lol
  8. Jun 5, 2014 at 12:42 PM
    #228
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Subbed. Removing my Diff Drop this weekend I hope.
  9. Jun 9, 2014 at 11:55 AM
    #229
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Just so I do this correctly...
    Can I just remove the aluminum spacer & reuse the bolts that are currently there? Or will I have to get the OEM bolts?
    Does everything look normal here(I bought the truck like this)?
  10. Jun 9, 2014 at 11:56 AM
    #230
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    OEM bolts as i believe the bolts for the spacer are too long.
  11. Jun 9, 2014 at 12:55 PM
    #231
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Gotcha. Calling the local dealership to see how much the bolts cost.
    I attached a .pdf of parts for that area of the truck.....just in case it helps anyone. I believe the Nut & Bolt part numbers are: Bolt - 90080-11283
    Nut - 90178-A0047
    I'm not sure if I need part numbers: 41654A & 41653B
    I think they are already on my truck but, if anyone wants to have a look at the photos I posted above and confirm this, it would be appreciated.
  12. Jun 11, 2014 at 11:04 AM
    #232
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    wow guys really..... take the spacer out, take the bolt and the spacer to the hardware store and get a bolt thats the proper lenght (real easy to figure out when you have the current bolt and spacer in your hand) and be done with it, no need to go to the dealer.
    Mully likes this.
  13. Jun 11, 2014 at 11:21 AM
    #233
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    1/2 x 5 inches. grade 8. get some Toplock nuts too.
    EsJ TX likes this.
  14. Oct 8, 2014 at 9:15 PM
    #234
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    I'm bumping this to counter a lot of recent statements about diff drop (spacers) being necessary for any lifts exceeding 1.5".
  15. Oct 8, 2014 at 10:42 PM
    #235
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    I agree with this... the only problems I see are cause by the damage from hitting the skid plate... which looks like it would have just F**KED up some parts anyway with that amount of force
  16. Feb 13, 2015 at 5:48 AM
    #236
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    We would not have this problem if toyota put lock out hubs on the front axle. Then everbody wins no more differential drops and less where and tear on cv boots and joints.
    Taco1999 and outlawtacoma like this.
  17. Feb 16, 2015 at 5:31 PM
    #237
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Awe. Then I'd be bitching about cleaning the mud out of the hubs so I can turn the locks. If you race, then you wouldn't want the stock setup anyway. If you don't, then it's nice to flip it on, do something you shouldn't, then flip it off. Did this on Saturday in a place I wouldn't have wanted to jump out of the truck.
  18. May 3, 2015 at 8:31 AM
    #238
    specjay
    specjay Active Member
    Jeremy
    Montreal
    2012-SR5-BLACK
    3" Pro-comp lift kit SPC Ucas 16" FJ cruiser TRD wheels gillcraft grille mod with the TOYOTA emblem Lorado access tonneau cover pop n lock tailgate
    Ok I just lifted my 2012 with the procomp prerunner 3" lift kit ( I have 23" from center hub to fender) But i have to mention that i also go with 285/75/16 tires. During the installation of the diff drop spacer i did not found it was not really a DD but a change of angle. So I decide to remove it but i took pictures of CV angle before removal and after. I also have to mention that the truck is not yet aligned. Please tell me what you think of it, i think its bad:
    With SPACER Driver side:
    without spacer:
    with spacer passenger side:
    without spacer:
    I have to admit it does a small change in angle if you look at the fins of the boots. And then I decided to do the inner cv boot mod with hose clamp but the first fin on the passenger side still in contact with the second even at 1" of slide. Does the alignment will help as my camber is positive ??
    I also want to know if you guys also slide the outter cv boot with a full 3" lift
  19. Aug 2, 2015 at 9:42 PM
    #239
    ETaco23
    Evan
    PNW
    Usually no one does the boot slide mod to the outers. Its just the inners that have the potential to wear and split.
    I was installing my DD kit and was looking at the fins. Though it does change the angle slightly, it more rotates the diff. So i found it actually made my inner fins touch near the bottom front of the boot. So i took it out and not looking back.
    I still may do the inner boot slide mod.
  20. Aug 3, 2015 at 12:31 PM
    #240
    JLink
    Josh
    Ocean, NJ
    Yea boot slide mod and no diff drop. Actually I don't even have the boot slide mod anymore. I changed my cvs.
