Remove the differential drop on your 05+ Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mjp2, Oct 15, 2010.
  1. Feb 24, 2017 at 7:16 AM
    #261
    G.T.
    G.T.
    CONUS
    If you have a 1st gen that you are lifting then add it, if it's a 2nd gen, then it is irrelevant and as seen earlier in this thread can be detrimental.
  2. Feb 24, 2017 at 7:17 AM
    #262
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Ummmm your shocks do not look installed correctly
    roguegs and lynyrd3 like this.
  3. Feb 24, 2017 at 8:20 AM
    #263
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    If this is true then why do so many on this thread have them on their second generation truck's,and are now taking them off ?
  4. Feb 24, 2017 at 8:22 AM
    #264
    G.T.
    G.T.
    CONUS
    Something about a fools and money, can't remember exactly how it goes.
    anthony250f likes this.
  5. Feb 24, 2017 at 8:27 AM
    #265
    lynlan1819
    Tacoma
    Lifted
    Yep LOL....A fool and their money soon parted !!!
  6. Sep 2, 2017 at 6:16 AM
    #266
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    This is the answer I was looking for. DD will not make any improvement but a lot damage.
  7. May 13, 2018 at 3:26 PM
    #267
    Solution.45
    Solution.45 Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    Does anyone know the bolt sizes? I'm taking mine off when I put my LT kit on (because why not do it while I'm under the truck). What are the OEM bolts that went in there before the drop kit went on? I didnt keep mine...
  8. May 14, 2018 at 11:14 AM
    #268
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Solution.45[QUOTED] likes this.
  9. May 27, 2018 at 9:49 AM
    #269
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    to drop or not to drop...?????
  10. May 27, 2018 at 4:44 PM
    #270
    lynyrd3
    Bill
    East Central Upstate NY
    ^ That is the question ............ I have the DD ,no problems . 1st lift was 1.75” 5100s in front ,no DD ,torn boots . Lift now is 2.5”, 6112s with DD , boots and angles good :notsure:
    Greg617 likes this.
  11. Aug 13, 2018 at 12:17 PM
    #271
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    So im considering ignoring all this noise about removing DDs. :lalala:
    I just put in 5100s in all 4 corners with 887xs up front and 1/4 spacers... I think i got 3+'' of lift up front now. Got the DD kit in the mail and I think im going to install it. If my off-road driving consists of gravel roads and beaches, why not install it right? Clearance is not a concern of mine.
    :notsure:
    lynyrd3[QUOTED] likes this.
  12. Aug 13, 2018 at 12:58 PM
    #272
    lynyrd3
    Bill
    I don’t think it will hurt anything :D
    Greg617[QUOTED] likes this.
  13. Aug 13, 2018 at 1:46 PM
    #273
    lynlan1819
    Tacoma
    Lifted
    If its already on the way.why are you even asking here about installing it.
  14. Aug 13, 2018 at 2:40 PM
    #274
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    Well, I because ordered it without reading this whole thread bashing DD and I could still not install it and return it. o_O
  15. Aug 13, 2018 at 2:49 PM
    #275
    lynlan1819
    Tacoma
    Lifted
    About as many guys install them as there is guys asking how too uninstall them.Too each their own.
    lynyrd3 likes this.
  16. Aug 13, 2018 at 2:55 PM
    #276
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    Fair enough. Lots of ways to set up these trucks and use and abuse them.
    Personally not worried about clearance so I think i'll be fine. Ill save the oem bolts in case my situation changes.
    lynyrd3 likes this.
  17. Aug 13, 2018 at 5:03 PM
    #277
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just noticed this thread and thought i'd share my experience with the dd. I've had mine on since 2007 with zero issues.
    Greg617 and lynyrd3 like this.
  18. Aug 13, 2018 at 6:23 PM
    #278
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I had to remove mine to get my (RCI) skid plate flush with the frame/crossmember
    lo2hi likes this.
  19. Aug 13, 2018 at 9:08 PM
    #279
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Dont do it!!!
    :bananadead:
    -RJM
  20. Aug 13, 2018 at 9:28 PM
    #280
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    Even if I only drive on pavement, snow covered pavement, and the beach 95% of the time?
    If so, why? Still haven't done it and appreciate the IMO advice.
