Removing a decal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by friendlyphil, Feb 17, 2016.
  1. Feb 17, 2016 at 10:18 AM
    friendlyphil
    friendlyphil [OP] Member
    2015 Prerunner Dbl Cab. Barcelona Red. TRD
    I just traded my 2005 Taco for a 2015 Taco. I hate the 2016. My Taco has the TRD decal on the back of each side and I want to remove them. What would be the best way to do it?
  2. Feb 17, 2016 at 10:18 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    22 Tundra
    heat gun on low.
    hair dry works fine too.
  3. Feb 17, 2016 at 10:26 AM
    CAM37
    CAM37 Well-Known Member
    2016 Black TRD Sport
    After you heat it, get a corner up and then pull back slowwwwwwwwly, going from one side to the other.
    Once you have it off, remove the residual adhesive with Goo Gone or Goof Off, both are good products. Use a microfiber towel so you don't scratch the paint.
    I helped even though you hate my truck. :luvya:
    DRHays10 and RNJNKE like this.
  4. Feb 17, 2016 at 10:27 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Hair dryer on low and they will come right off.
  5. Feb 17, 2016 at 10:48 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    They just peel off nothing needed but what God gave ya
  6. Aug 30, 2016 at 3:47 PM
    DRHays10
    DRHays10 Well-Known Member
    Dylan
    2016 Tacoma Sport 4X4
    i tried peeling mine off and used a heat gun, neither has worked and goof off isnt doing anything to it!!?? WD-40 is working but am i doing anything wrong before i start on the other side?
  7. Aug 30, 2016 at 3:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    the goof off/WD 40 is to remove the residual glue after the decal is off, not remove the decal per se.
    If the heat isn't working, you aren't getting it quite hot enough. Get one corner soft, and start the peel. Then heat ahead of the peel, and slowly remove it.
  8. Aug 30, 2016 at 4:03 PM
    qxrtz4321
    qxrtz4321 Well-Known Member
    Mitch
    Montana / Washington
    Peeled mine off in the middle of the day without any additional heat... Although I'm in Texas the sun was shining on it and it was like 95 that day.
  9. Aug 30, 2016 at 4:05 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Just work the edges with your fingernail. If you get a good piece to come up, peel it along the side (double it back on itself, don't pull up). It may just come off in small bits, and pieces. Once you get all the decal off, as it's been mentioned, use Goo Gone / WD to get remaining adhesive. Once clean, and dry, finish up with some rubbing compound, and wax.
  10. Aug 30, 2016 at 4:20 PM
    DRHays10
    Dylan
    this shit is tough! that goo gone isnt making a dent and the WD-40 isnt doing too hot either. used a plastic scraper we use on aircraft and it is chipping away slowly
  11. Aug 30, 2016 at 4:24 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Patience is your friend when removing the adhesive. DO NOT try to rush, or you might take some paint up! Just apply more heat, and work it slowly. Goof-Off has been reported to be more harmful to the clear coat then goo-gone.
    I just rolled the adhesive off using my thumb. Yeah, it hurt, but it won't hurt the paint.
    DRHays10 likes this.
