Removing and Painting emblems black
Discussion in 'New Members' started by Winks18, Oct 29, 2019.
  1. Oct 29, 2019 at 9:01 AM
    Winks18
    Winks18 [OP] Member
    2017 red Tacoma TRD off road
    Hey guys! New to the taco world. Struggling to find the right thread for my question... Looking for advice on removing emblems and painting black. What adhesive you should use to put them back on and what sort of process to paint them the right way. Tried plastidip and it didnt work to well. Looking for something a little more durable and weather proof. Thanks!!!
    buckhuntin-tacoma likes this.
  2. Oct 29, 2019 at 9:04 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
  3. Oct 29, 2019 at 9:04 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
  4. Oct 29, 2019 at 9:09 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    I removed them with heat and fishing line. Remove old adhesive with goo gone or mineral spirits. Sanded, sprayed with several coats each of adhesion promoter, paint, and clear coat. Adhesive to use is 3M "Super Strength Molding Tape". Its been a couple years and they still look the same as when I did it
  5. Oct 29, 2019 at 9:09 AM
    Winks18
    Winks18 [OP] Member
    Thanks for the advice! What sort of adhesive does it come with? If any.
  6. Oct 29, 2019 at 9:14 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Plastidip. It's a miracle product if you do it correctly. Don't mess around taking the badges off, just 'dip them. Watch some YouTube vids and dooo eeeeet.
  7. Oct 29, 2019 at 9:17 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    There's an adhesive glue I see recommended on this site quite often, do not use that. Removing the emblems later will result in taking the paint with it. 3m tape I believe is the answer. Good luck cutting it, if you get it right, you have way more patience than I do.
  8. Oct 29, 2019 at 9:19 AM
    Winks18
    Winks18 [OP] Member
    By cutting you mean cutting the tape? Haha
    Taco critter likes this.
  9. Oct 29, 2019 at 9:20 AM
    toyotatacomaTRD
    I mean cutting the tape so you can't see it after you install. Fishing line should be used to remove.
  10. Oct 29, 2019 at 9:21 AM
    Winks18
    Winks18 [OP] Member
    Ya I realized that's what you meant. And goo gone to remove adhesive from truck?
  11. Oct 29, 2019 at 9:22 AM
    Minimag95
    Niles
    Annapolis, MD
    He means cutting the tape to re-apply the emblems. You cant just put a long strip or you'll see it behind the letters. You have to cut it to fit the corners of all the letters. Just cut small pieces at a time, its not that bad just takes patience. And don't spray them on the truck. Do it right the first time, it'll look better and you'll never have to do it again.
  12. Oct 29, 2019 at 9:23 AM
    danielsthomas57
    danielsthomas57 Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    plasti dip or just buy a set of new ones that are black.
  13. Oct 29, 2019 at 9:24 AM
    toyotatacomaTRD
    They don't make them in 3rd gen letter's which has been an issue for a while. Not sure why they haven't figured out that nobody wants chrome on a vehicle anymore.
  14. Oct 29, 2019 at 9:25 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Plastidip. Its easy and works great if you follow the directions. I did mine 5 years ago and they still look perfect.
  15. Oct 29, 2019 at 9:26 AM
    Minimag95
    Niles
    Annapolis, MD
    Goo gone, and/or heat to help peel it off
  16. Oct 29, 2019 at 9:27 AM
    Winks18
    Winks18 [OP] Member
    How do you reply to a certain comment on here?
  17. Oct 29, 2019 at 9:29 AM
    danielsthomas57
    Thomas
    Virginia
    oh well plasti dip it is. at least 8 coats and make sure to clean with alcohol before hand.
  18. Oct 29, 2019 at 9:30 AM
    Minimag95
    Niles
    Annapolis, MD
    Click "quote" underneath the post that you want to respond to. Then type your response
  19. Oct 29, 2019 at 10:12 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW... I too agree with plasti-dip 8-10 coats.
  20. Oct 29, 2019 at 11:19 AM
    toyotatacomaTRD
    I made this comment earlier and realized I hadn't checked in a while. There appears to be a eBay vendor selling 3rd gen emblems in black with 3m tape already applied. I just placed an order. $26 shipped for two of them. I'll update when I see the quality of them.
