Removing bedsides?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilhank, Feb 4, 2011.
  1. Feb 4, 2011 at 4:03 AM
    lilhank
    lilhank [OP] Well-Known Member
    Mississippi
    06 Tacoma 4dr 4x4 LWB
    Tried the search function and did not come up with much.I am wanting to remove my besides and replace with new ones.What is the best way to remove the old ones?
    Thanks,
  2. Feb 4, 2011 at 6:45 AM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Blackhawke88 showed me after he put fiberglass sides on his. It appears that you just go from underneath and start unbolting (12mm socket and extension).
    RZ Rob
  3. Feb 4, 2011 at 7:57 AM
    lilhank
    Mississippi
    I should have worded my question a little better.I am talking about the "trd off road" sticker.sorry about that.Thanks anyhow for the reply EZ Rob
  4. Feb 4, 2011 at 8:04 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    ha! Socket wrench would take the stickers off too. There might be specfic solvent to use to remove decal. Search "debadge".
    I have used 'goo gone' sparingly but some say it is bad for the paint.
  5. Feb 4, 2011 at 8:10 AM
    PCarnathan
    PCarnathan Member
    Pat
    2011 Tacoma Access Cab 4x4 V6
    I use a hair dryer to soften the decal up a bit, then peel it off. A light-duty solvent to remove any leftover adhesive, then clean to remove the solvent.
    There's a non-toxic Goo Gone product that won't hurt your Toyota paint.
    Pat in Menifee, CA
    http://www.patcarnathan.com
  6. Feb 4, 2011 at 8:23 AM
    RedDouble
    RedDouble Member
    Atl
    08 PreRunner SR5
    Astro tools makes a giant eraser that is usually chucked up in an air drill or a cutoff tool. It will completely remove the stickers and adhesive. It is available at most body supply stores.
    http://www.astrotools.com/default.aspx?toolsnum=1232&
    Be very careful with it when it is new as the sharp corners will dig in to the paint. The first time I used one I did a little damage before I rounded the edges on a piece of scrap metal. Work slowly on large stickers and work on different areas to prevent excessive heat build up.
  7. Feb 4, 2011 at 8:50 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Grab a corner and remove .., that's what I did
  8. Feb 4, 2011 at 10:19 AM
    juicedgsr95
    juicedgsr95 Member
    Raleigh, nc07
    07 PreRunner TRD Sport
    and if there is any residue left behind, WD-40 will take it off.
  9. Feb 4, 2011 at 10:20 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Or Windex
