Removing coils without compressor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinramsay, Jun 18, 2012.
  1. Jun 18, 2012 at 6:40 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    There was a thread on here that showed how to remove the coils off the stock struts on here and I searched and cant find it. Anyone know where it is?
  2. Jun 18, 2012 at 6:56 PM
    sgrappone
    sgrappone Well-Known Member
    Scott
    Moncks Corner, SC
    04 AC 4X4
    It can be done. You have to load the front suspension by means of a jack under the LCA. You then must mark and note the position of the LCA bolts and loosen them DO NOT REMOVE them. You then remove the three top plate bolts and one strut bolt and lower the suspension slowly. The only down fall is getting the LCA bolts in the previous position. There is a thread in reference to this but I don't recall where I saw it.
  3. Jun 18, 2012 at 6:59 PM
    sgrappone
    Scott
    Moncks Corner, SC
    04 AC 4X4
  4. Jun 18, 2012 at 7:08 PM
    austinramsay
    Austin
    Yuma, Arizona
    I saw that, ill probably give that a try then once my 5100s come in. Thanks! :) but i wanna see that thread on here cause it looked like a better method.
  5. Jun 18, 2012 at 8:41 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Having used coil spring compressors at several shops before, the method in the video actually looks significantly safer. No lie.
  6. Jun 18, 2012 at 8:51 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    damn. good luck
  7. Jun 18, 2012 at 8:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    At least chain the coils to something and stand clear if you're gonna do it the ghetto way. I wouldn't dare try it myself. There's a lot of stored energy there.
  8. Jun 19, 2012 at 12:07 AM
    austinramsay
    Austin
    Yuma, Arizona
    Haha yeah i was thinking itd be more expensive to take to a shop and if their was a safe way to do it i would just do it. i called around and got some good prices so ill just take em somewhere. :thumbsup:
  9. Jun 19, 2012 at 12:24 AM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
  10. Jun 19, 2012 at 12:31 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    x 10000000
    I did this to put my eibachs on my 5100's on my old truck, it's extremely easy, and extremely safe, there is no way that coil is coming out at you!
  11. Jun 19, 2012 at 7:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Bingo....
  12. Jun 19, 2012 at 8:07 AM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    i rented coil compressors from autozone. they were a $55 down payment but i got all my money back when i returned them
  13. Jun 19, 2012 at 8:11 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I've done a method similar to this numerous times on tacomas and tundras.
    More likely to lose limbs with the POS compressor from autozone.
    Safest way to do it is have a shop swap the springs. I never once felt it was sketchy or felt at risk doing it this way.
    If anyone in Tucson needs help let me know. Easy peasy.
  14. Jun 20, 2012 at 7:51 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
  15. Jun 20, 2012 at 7:58 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I couldn't even focus on that video because of the macintosh man's voice. It cracks me up every time.
  16. Jul 5, 2012 at 8:07 PM
    go8soccer
    go8soccer Memba
    Grovetown, GA
    '08 Super White DC LB Prerunner Sport
    Leaf TSB, front Billie 5100's (1.75"), 265x70x17 BFG Rugged Terrain
    I have a 2nd gen, but can't imagine the 1st gen being any different (or any other car for that matter.. suspensions are pretty similar across the board unless you have leaf springs up front).
    I'm not a mechanic by any means, but I know what a wrench is and how to use it. I followed the video verbatim... I'm typing this reply now.. so i didn't lose any fingers or limbs. If you're going to attempt DIY, don't rush, be safe, and follow exactly what the video says and you'll be fine.
    IMO:
    1) I saved money by doing it myself
    2) I know it was done right, b/c I did it myself
    3) It was a learning experience because I learned more about my truck that I would have otherwise shrugged off because I paid someone else to have the fun
    4) I agree with others... this method IS safer (and probably quicker) than the rental spring compressors (as long as you do everything in order of the video).
    Feel free to PM me if you have any questions about the experience :)
  17. Jul 5, 2012 at 10:57 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    X Elevendy million!
    I just did this method today. It's almost derp how safe and easy it is.
  18. Jul 5, 2012 at 11:57 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    i would go with this route or just buy a set from sears. it's come with lifetime warranty if it ever breaks(mine did once). i've put it to good use so it's money well spent.
  19. Jul 6, 2012 at 10:51 PM
    austinramsay
    Austin
    Yuma, Arizona
    Ended up taking to a shop, but how did you get the center bolt on the strut to come off? Mine just kept spinning with the shock?
    Haha yeah i probably should but i guess that method works without em
  20. Jul 7, 2012 at 7:41 AM
    License2Ill
    Ian
    You hold the strut shaft with a 7 or 8mm open-end box wrench or small crescent.
    Actually removal was easy. But reinstall was a bitch. I couldn't loosen the cam bolts. So I used ratchet straps and verbal abuse to pull the lca down to line up the hole for the bottom strut bolt..
    Next time going to the shop fer sure.
