Removing EFI fuse for deckplate...
Discussion in 'Performance and Tuning' started by Tman12, May 22, 2011.
  1. May 22, 2011 at 12:57 PM
    Tman12
    Tman12 [OP] =T=
    Taryn
    VA
    01 Limited Double Cab 4x4
    Brush Guard, Flowmaster,Infinity 12" Sub,Vent Visors, Michelin AT2,Powder Coated stock alloy rims, yakima roof rack and bike mounts.
    On some of the deckplate mod write ups i have seen, it is recommended to remove the EFI fuse in order to reset the system in order to let it adjust to the larger amount of airflow. However, the only write ups that discuss this are ones for 4 runners performing the mod. Should I do this to my tacoma as well? I plan on doing the mod tomorrow and would like to know if it would help.
  2. May 22, 2011 at 1:43 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
  3. May 23, 2011 at 11:30 AM
    Tman12
    Tman12 [OP] =T=
    Taryn
    VA
    Looks like its x-everyone huh?
  4. May 23, 2011 at 9:29 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    I pulled the 15a efi fuse when I did mine, and again when I put new a muffler in. Idk if I does anything tho my truck didn't drive any different. Shifting points were still the same...
  5. May 24, 2011 at 10:04 AM
    Tman12
    Tman12 [OP] =T=
    Taryn
    VA
    Yea, I did my mod and pulled my small EFI fuse. Everything went well and I couldnt really tell a difference in shifting like they said might happen. Oh well, good mod regardless.
  6. Jun 6, 2011 at 11:04 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I had a custom cat-back installed a few weeks ago and my CEL has been on ever since. I plan on doing the deckplate mod this week and have been reading up on it.
    After reading this I went ahead and pulled the EFI 15a fuse and low and behold my CEL is now off!! hope it stays off cause staring at that thing everyday makes me rather uneasy..
    fyi - At first I pulled the fuse and left it out and my truck would not start. I put it back in and it was good to go.
    thanks for the info
  7. Jun 10, 2011 at 7:11 AM
    TIPICOTACO
    Tyler
    nw nj
    after pulling the fuse and turning off my CEL, after only 20 miles the CEL is back on. I then pulled the fuse again only to have the CEL pop back on after another 20 miles.. Obviously something aint right..
    this is not from the deckplate cuz I didn't do it yet, this stems from a new cat-back.
    any ideas?? guy at URD said the o2 sim will not fix the prob?? i'm stumped
  8. Jun 10, 2011 at 7:53 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    All you need to do to reset the ECU is pull the battery cables off the terminals and hold the brake pedal down for 20 seconds. Once you're done with the install connect them back to the battery. It is recommended that you do this for any mod, but the ECU will adjust to the larger amount of airflow regardless if you reset it or not it will just take longer.
  9. Jun 10, 2011 at 8:15 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    When I did the elbow mod I just disconnected the POS side of the battery, did the mod, then reconnected the cable. Like YamahaDave said, this speeds up the ECU learning curve. If you just did the mod but left everything connected, it would still learn the change-but will take longer.
  10. Jun 10, 2011 at 8:58 AM
    TIPICOTACO
    Tyler
    nw nj
    I had it checked and cleared twice, it was PO420.
    I havn't taken a look at the rear o2 since it was re-installed by the shop. Mayb they damaged the sensor when they welded the bung back in.
    Thanks for the info YamahaDave and Ridgerunner, I'l reset the ECU and c if that does it.
  11. Jun 13, 2011 at 10:05 AM
    TIPICOTACO
    Tyler
    nw nj
    I reset the ECU without any issue, I then took a 300 mile round trip to Philly. The CEL stayed off and gas mileage was as usual for the whole trip. BUT the next morning I had a few errands to run around town and after only 10 miles the CEL came back on :confused:.
    I just did the deck-plate mod this morning and reset the ECU again. Hopefully this time things will work themselves out. If not, my rear o2 sensor must be shot..
  12. Jun 13, 2011 at 7:54 PM
    Ridgerunner
    Frank
    San Francisco
    Or your gas cap may have lost its seal too-
  13. Jun 14, 2011 at 8:45 AM
    TIPICOTACO
    Tyler
    nw nj
    How do you check for that?
    my CEL came on after 25miles again this morning after the deck-plate mod and resetting the ECU.. this is getting frustrating!
  14. Jun 14, 2011 at 9:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    What catback did you put on?
  15. Jun 14, 2011 at 9:21 AM
    TIPICOTACO
    Tyler
    nw nj
    I had a local shop bend me stainless pipes (2.25") and weld on a Magnaflow 18" offset in/center out.
    they welded the rear o2 bung back in and I'm startin to think that they damaged it.
    The guy did say that there's a leak in the exhaust manifold and a slight leak at the upstream side of the cat. Both however were there before the new cat-back and I never had a CEL previously go on in the 5 months that I owned the truck
  16. Jun 14, 2011 at 9:25 AM
    98tacoma27
    Ben
    Beech Creek
    It's either one of two things for a 420 code; CAT or rear O2. The rear O2 is a lot cheaper to put on than a new CAT. I'd try that.
