Removing line stickers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacomaprerunner, Feb 5, 2019.
  1. Feb 5, 2019 at 8:30 AM
    07tacomaprerunner
    07tacomaprerunner [OP] Member
    Jake
    2007 red Tacoma prerunner TRD
    Stock
    Can I just pull off the line stickers that go from front to back of the sides? Or do I need some special tools
  2. Feb 5, 2019 at 8:34 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Just get them warm, lift an edge, and pull.
  3. Feb 5, 2019 at 8:55 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Those are called pin stripes. You can remove them, but depending on the age of your truck, you may see a difference in the paint under there.
  4. Feb 5, 2019 at 9:07 AM
    07tacomaprerunner
    Jake
    Stock
    It’s a 07
  5. Feb 5, 2019 at 9:26 AM
    Fullboogie
    Dave
    Houston
    Yeah, the paint under those stripes is likely in pristine condition - the rest of your truck is probably not. Might be a good excuse to spend a day with the clay bar/polish/wax.
  6. Feb 5, 2019 at 9:30 AM
    07tacomaprerunner
    Jake
    Stock
    And the rest of the paint was a different shade/color right?
    DirtTaco likes this.
  7. Feb 5, 2019 at 9:48 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  8. Feb 6, 2019 at 5:11 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Plan to paint correct your truck. And 07 red (what color the truck is makes all the difference in the world) will likely have shadowing from the stripes.
    Use a heat gun or hair dryer carefully with patience. Do NOT scrape or scrub the adhesive off. You’ll marr your clear coat.
