Removing lower control arm bushings (HELP)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Aug 30, 2016.
  1. Aug 30, 2016 at 11:13 AM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Hello ill be changing my lower control arm bushings today wanted to see if there's any tips on removing the bushings from the control arms that will make my job easier ? Thanks!
  2. Aug 30, 2016 at 11:17 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Have heard it's a HUGE pain to remove them. Most I have read up on actually just get new lca's because of it. Hopefully someone with more knowledge will chime in on the removal process though.
  3. Aug 30, 2016 at 11:43 AM
    Animus313
    Animus313 Well-Known Member
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    I think it depends on which bushings you are putting back in. I did mine and replaced them with whiteline bushings. I took the LCA off and used the bottle jack method to pop out the old bushings. It takes some force but all in all it was pretty easy. Use some break free to free up the rust. Clean up the LCA and push the new bushing in. I used a rubber mallet to lightly tap them in. I think the biggest issue people might have is the cam bolts. if any of them are rusted in place its difficult to get them out and some have had to cut them out. You can get replacements. I think toytec has them. Heres a good thread on it.
    https://www.tacomaworld.com/threads/lca-bushings-oem-energy-suspension-whiteline.394935/
    JMJordan and FirstGen Jer like this.
  4. Aug 30, 2016 at 11:46 AM
    OdinBow
    OdinBow Just an idiot out wandering around CO.
    Mitch Cumstein
    Erie, CO
    2011 Timberland Mica T|X Pro
    None, but willing to learn.
  5. Aug 30, 2016 at 3:32 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Yep bottle Jack method ftw.
    You can also use the ball joint press method, here's a really good video on how to use it. Can be confusing if you'd never used one before as it can be used multiple ways. But you should be able to get them super easy with the bottle jack (just put a lot of pressure on it, and smack the control arm eyelet with a hammer and they'll literally shoot out, no heat needed), as well as just tapping the new bushings in like mentioned which is what I did as well. Or use the ball joint press. But that press Can be so precarious, I hate using it. If nothing else the vid will give you an idea of what to expect, then you can go about it how you want. The other threads posted above have all the other info you'll need. There's a vid in the whiteline thread iirc that shows the bottle jack method.
    https://youtu.be/aPbL9HTHZg0
  6. Aug 30, 2016 at 3:36 PM
    Animus313
    Post Falls/CDA, ID
    2000 Tacom xtra cab
    If you aren't using whitelines I think you need to keep the outer metal jacket and reuse it. Maybe someone else can confirm this since I used whitelines.
  7. Aug 30, 2016 at 3:38 PM
    NightProwler
    Harlan
    Maricopa, Az
    It's a pain when they replace them with the poly bushings. Because the actual rubber has to be burnt and scraped out of the sleeve as the sleeve is left in. Whereas oem rubber ones the whole thing is pressed out and new one in. A lot more involved with polys. And on top of that they squeak from what I hear. Not worth it imo.
  8. Aug 31, 2016 at 6:26 PM
    fireman1073
    fireman1073 Well-Known Member
    stephen
    new bedford,mass
    06 4runner sport v6
    none yet
    Hole saw makes short work of the rubber..falls right out then if need be chisel out the metal sleeve
  9. Feb 22, 2019 at 9:05 PM
    Jultepod
    Jultepod Well-Known Member
    Oahu, Hawaii
    2013 Gray Tacoma TRD
    K&N cold air, Exhaust, rims and tires, 3" king extended travel coilovers and total chaos UCAs, rear diff breather mod, CBI off-road ditch brackets with Cali raised LED pod lights and painless wiring harness, 4xinnovations rock sliders, cab mount chop.
    Obviously this is an OLD thread. But possibly someone can shed some light on it. I have tried the torch and bottle jack methot. Just bent the shit out if the washer and just ate up the bushing. Now I have the sleeve still stuck inside. Bought a ball joint press. But the sleeve has a lip at the end and the cup of the press doesnt have any metal on the arm yo use as leverage. I'm about to cut the lip off the sleeve and try to use a cup that fits in the LCA and push it out that way. It that doesnt work idk what to do. I dont have access to a cutting torch either so I cant just cut the bitch out.
  10. Feb 22, 2019 at 9:44 PM
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    i bought a harbor freight press for this job and a bearing splitter. it worked. however the landcruiser guys just hammer out the sleeve. either use an air chisel if you have one or a cold chisel and a 2 lb hammer.
    hopefully this pic gives you seen idea. not the right vehicle but same idea.
    https://goo.gl/images/hmx7JE
