Removing manual window regulator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jamescamp11, Jun 5, 2008.
  1. Jun 5, 2008 at 2:25 PM
    jamescamp11
    jamescamp11 [OP] Active Member
    Denver, CO
    2011 Double Cab SR5
    I just purchased some replacement speakers for the right & left front doors and will have to remove the entire panel on the doors to get to the old speaks'. I can see where all the screws are to remove the panel(s) but how do I go about removing the window regulator arm (little arm to roll windows down)? I haven't really attempted to try but assume someone on here has an easy way of doing it before I try it myself and break the damn thing. :) Thanks!
  2. Jun 5, 2008 at 6:30 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    If Toyota hasn't changed the design from the 1991's it's easy.
    Take a rag and get an edge between the crank and the door panel. Then pull the ends back and forth. More and more of the cloth will work it's way in gently pushing the handle off the shaft it's attatched to. When you reassemble the door the handle just pops right back in place.
  3. Jun 5, 2008 at 6:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Didnt they switch to useing "C" clips in the window roller uppers?
  4. Jun 5, 2008 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "submit" button went full auto on me....
  5. Jun 5, 2008 at 7:51 PM
    hicksy712
    hicksy712 Member
    Aaron
    TN
    98+ frontend swap with clear headlights, tint, 6" fabtech, 15x12 powdercoated alloys, 35x15.50 SX's, 5.29 yukon gears, 1.5" wheel spacers, k&n filter. paint and line-x to come.
    I've got a 97 model and the rag trick is how i got mine off. Make sure your windows are either up or down so you can make the driver and passenger side in the same position when you reinstall them.
  6. Jun 5, 2008 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I never tried the Rag methode! I actually bought a stupid tool to do it. :mad:
  7. Jun 6, 2008 at 8:19 AM
    jamescamp11
    Denver, CO
    2011 Double Cab SR5
    So two things are preventing this dang panel from coming off. (1) Window regulator, and (2) the door handle. I will attempt the rag method but I am still a little confused on how I am to remove the handle. This is such a pain in my ass. Why couldnt they have made the speaker more accessable. I will search the net to see if I can shed some extra light on this.
    Thanks for your help!
  8. Jun 6, 2008 at 8:27 AM
    jamescamp11
    Denver, CO
    2011 Double Cab SR5
    (Chris4x4) - would I be able to determine whether or not it is a "C" clip design by looking at it or is there another way to determine this? Also, if it is indeed a "C" clip design, how would I go about removing it?
    Thanks!
  9. Jun 6, 2008 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used a very thin needle nose plier. They make a toll for removeing the handle, and I bought one, thinking I would need it. Never did and ended up giveing it away. You can call a car adio shop and they will tell you what it is called. I couldnt "see" it, but I felt it useing the pliers. WHen I removed it, It was simple to re install. :)
  10. Jun 9, 2008 at 8:26 AM
    jamescamp11
    Denver, CO
    2011 Double Cab SR5
    The "cloth" trick was super easy and worked just fine. Thanks Chris4x4 and thanks to everyone else for the help.
    Quick summary: Took 2 flat head screw drivers and wedged them in on the sides creating a smally gap between the panel and the arm itself. Took a small piece of cloth, worked it in from the bottom and started working the cloth back and forth like a saw. Continued to work back and forth while pulling slightly upward and the clip exposed itself enough for me to take needle nose and pull it straight out. After clip is out the arm pops right off.
  11. Jun 9, 2008 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool! Glad you got it figured out. :)
