Removing Rust from chip??
Discussion in 'Detailing' started by ETaco23, Mar 14, 2010.
  1. Mar 14, 2010 at 8:14 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Ive searched guys but cant find much info. I got a couple chips that have rusted and need to get them fixed, but not sure the best way to remove the rust before doing touch-up paint.
    Any help appreciated! thanks...
    Oh and there about the size of a pee or pebble..
    I aslso have a buch of narlly rock chips along my rocker panels I need to fix, theres a bunch!:eek:
  2. Mar 14, 2010 at 8:18 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Dremel..
  3. Mar 14, 2010 at 8:22 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    X2... with as many chips as you have a pick would take WAY to long.
  4. Mar 14, 2010 at 8:35 PM
    ETaco23
    Evan
    PNW
    well only 2 are rusted, and the others down the rocker panel, are just deep and not rusted.
  5. Mar 14, 2010 at 8:35 PM
    ETaco23
    Evan
    PNW
    And what attachment would you use on the dremel?
  6. Mar 16, 2010 at 6:46 PM
    ETaco23
    Evan
    PNW
    Just a little bump...:)
  7. Mar 19, 2010 at 9:12 PM
    ETaco23
    Evan
    PNW
    Again.. Bump!
    Which attachment for the dremel will work good but not effect the surrounding paint?
  8. Mar 28, 2010 at 4:38 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
  9. Mar 28, 2010 at 5:10 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Yea, the above will work. But for the rusted ones try a sharp pointed pocket knife and dig as much rust as you can out of the chip. If there is rust left in the hole use OSPHO or Naval Jelly. Apply it in the hole with a tiny artists paint brush to apply into the hole not getting the brush wet enough to run onto the paint. Let it set per the instructions and touch up with paint.
    I have dug the rust out of pin hole size places with an xacto knife. But your chips sound bigger and deeper and you may not be able to dig all the rust out. .
    So use the OSPHO or Naval Jelly to treat the rust. Be careful with the OSPHO it is an acid and will not be good for the paint but it kills rust good.
  10. Mar 28, 2010 at 6:33 PM
    ETaco23
    Evan
    PNW
    Awsome! yeah the 2 that are rusted are pretty deep, and one has been there for quite awhile. So I know its ganna be a bitch to get the rust off. So Im thinking a dremel will work pretty good. But I will try the knife first. thanks!
  11. Jun 3, 2010 at 3:54 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    Try a Magic Eraser...
  12. Jun 3, 2010 at 8:47 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Just scrape it out carefully with a dental pick.
  13. Jun 3, 2010 at 9:20 PM
    ETaco23
    Evan
    PNW
    I got the rust out... I just used some light sand paper. And was careful not to damage the good paint. Got it touched up, but I still need to put aother couple coats on it.
    Thanks for the tips and help guys.. :)
  14. Jun 14, 2010 at 4:10 PM
    TacticalTaco
    TacticalTaco Active Member
    Victoria, BC
    O8 V6 4X4
    I've got exactly the same issue, two stone chips that started to rust immediately. Really small like an 1/8 of an inch in diameter. I was thinking of using a solvent on there to get the rust out like Hoppe's #9 or something, it gets rust off guns no problem. Then I can use some touch up paint on them. I'm a little worried about the solvent getting under the good paint though. At the dealership they told me to use a wire brush, but that would be impossible without marring the good paint.
  15. Jun 14, 2010 at 4:45 PM
    ETaco23
    Evan
    PNW
    for smaller holes I think a dremel would workk better. mine was big enough to use a corner of sand paper.
