Removing Scratches on Glass?
Discussion in 'Detailing' started by OffroadToy, Oct 27, 2009.
  1. Oct 27, 2009 at 9:57 AM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I purchased a used Snug Top canopy and noticed the tinted windows have very light scratches...only noticeable with direct sunlight. Is there a way to get rid of them, or make them less noticeable? The scratches appear to be like a scotch brite pad or something similar was used on the widows in a couple spots.
  2. Oct 27, 2009 at 10:04 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You can polish the glass with a compound that is made specifically for polishing glass, but it is a pain in the ass, and will take you quite some time. You will also need a buffer that runs at about 800-1000 rpm. In most instances, you want to remove the glass to get an even polish, but it is not always necessary.
    I cant think of the name of the compound that is used, but if i remember, I'll post it up.
