removing scuff from plastic- need help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dayNnite4, Aug 15, 2012.
  1. Aug 15, 2012 at 10:21 PM
    dayNnite4
    dayNnite4 [OP] We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    i was backing into my garage tonight and since the light burned out, i couldnt see all that well and the passenger side mirror rubbed against the white painted metal side of the doorway. theres a stripe of while about an inch long on the mirror and im wondering if anyone had any remedies for getting this off =/ thanks!
  2. Aug 16, 2012 at 5:45 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    just get a sponge with a scratchless scruby side and just scrub off the paint :cool:
  3. Aug 16, 2012 at 5:50 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2017 trd off-road dcsb
    wd40 then wax it after.
  4. Aug 16, 2012 at 5:53 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    plastic-x plastic polish?
  5. Aug 16, 2012 at 7:23 AM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    thanks for the help! a combination of wd 40 then a soft scrubby pad did the trick. idk why i didnt think to use wd 40 in the first place.. it fixes everything!
  6. Aug 16, 2012 at 10:19 AM
    trailotter
    trailotter Well-Known Member
    Michael
    Liberty, MO
    Toothpaste and a soft cloth will polish gently. Great for taking out paint scrapes.
  7. Aug 16, 2012 at 10:29 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    its funny i have the same white mark on my pass. mirror
  8. Aug 17, 2012 at 8:22 AM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    well the above remedies def worked.. give it a try!
