Removing sealer from trim?
Discussion in 'Detailing' started by cmouse, Jan 12, 2010.
  1. Jan 12, 2010 at 8:36 PM
    cmouse
    cmouse [OP] Well-Known Member
    Salt Lake City, UT
    09 Tacoma Dbl Cab Barcelona Red
    So I bought a red truck and I am worried about the paint fading and oxidation. I had the "protection" sealer applied by the dealer and it looked good at first (sucker). Now a couple months later where the sealer or whatever product they used is showing itself on the handles and trim. It looks like a 3rd grader went nuts with the Turtle Wax! Any thoughts on how to clean this mess up? No offense to the 3rd grade set.
  2. Jan 14, 2010 at 6:13 PM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road MGM
    Try some all purpose cleaner (Simple Green) mixed with a bit of liquid dish soap. Both are semi-strong degreasers. I use a small soft brush or toothbrush if the wax is on textured black trim. Good luck.
  3. Jan 15, 2010 at 6:12 PM
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    If it's on the door handles and the trim that joins it I would get one of those Magic Erasers. I got a little wax on my gf's Trailblazer on the handles in a couple spots and got one of those and got it right off.
  4. Jan 17, 2010 at 10:24 AM
    Tdup
    Tdup Well-Known Member
    Trey
    Columbia, SC
    ‘15 TRD Sport 4x4 DCSB
    2”in. leveled, 275/70/17 BFG ATs, Redarc brake controller, Ludwig helper springs, CamLocker tool box.
    Sounds like your dealer just did a shitty job on your truck. IMO take it back and complain about it, I'm sure you dealer will take care of it, if not write Toyota and they will for sure take care of your problem.
