Removing stock "tweeter" with coax speakers?
Discussion in 'Audio & Video' started by JBTuncc, Dec 7, 2009.
  1. Dec 7, 2009 at 2:05 PM
    JBTuncc
    JBTuncc [OP] Well-Known Member
    Charlotte, NC
    05 TRD Sport DC 4x4
    Should I remove the stock so called tweeter from the truck when i install coax speakers in the front doors? If so is it ok just to leave the wires hanging there? They aren't set up to where if the tweeters are disconnected the bottom speaker won't work are they? I wouldn't mind leaving them attached I just don't want to mess up the sound quality of the new speakers. Sorry I'm so terrible at car audio....
  2. Dec 8, 2009 at 8:56 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Just clip them and cap them. You can just leave them in place.
  3. Dec 8, 2009 at 9:13 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    Take back your coaxs and get a component set of speakers, your ears will thank you. You can get some fairly cheap and they sound great. I bought my Kicker components 5 1/4" from Crutchfield outlet for around $100.00. You will already have the door panel off to install the larger speaker, install the tweeter and fasten the crossovers on the inside of the door. Problem solved and your system sounds better.
  4. Dec 8, 2009 at 1:48 PM
    JBTuncc
    Charlotte, NC
    05 TRD Sport DC 4x4
    I don't recommend crossovers in the door. Done that before and they will fall apart. As for the components I am running them off of the stock headunit so I think the coax's will do better. Plus I got the coax's for 35 bucks. i may replace them later but Polk coax's should be fine for me.
  5. Dec 8, 2009 at 1:51 PM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    You would be surprised.
    Just drop some nice coax (I like boston acoustic) in the doors and leave the OEM tweeters there and hooked up. I think it sounds great.
    Its a simple upgrade.
  6. Dec 8, 2009 at 2:36 PM
    JBTuncc
    Charlotte, NC
    05 TRD Sport DC 4x4
    Nice. So you say that the stock tweeter won't throw off the impedence? I'm not familiar with all that...
  7. Dec 8, 2009 at 2:39 PM
    rutherk1
    09 Silver TRD 4door
    It will be fine.
  8. Dec 8, 2009 at 4:20 PM
    mwerner1
    mwerner1 Active Member
    New Fairfield, CT
    09 Mag. Grey TRD Sport
    Rebadged, 20% Tint all-around, Alpine 9886 head unit, Infinity Kappa Component Speakers, MTX Jackhammer Amp, Extang SolidFold Bedcover, In-Channel Vent Visors, Satoshi Grille, Aux Lamps Behind the Grille, Bed Lights, HID Fogs, Yellow Lamin-X on Fogs
    I installed infinity kappa components and they sound amazing, the only pain was getting the tweeters to fit the mounting bracket, if i were to do again i would purchase the brackets from tacotunes. But I do recommend to replace the tweeters and power the components with an amp
  9. Dec 8, 2009 at 4:27 PM
    rutherk1
    09 Silver TRD 4door
    Yeah. That is the best route, buy components, amps run oxygen free cable the trade off is the labor and cost.
    If you just want to spend 100 bucks to simply drop in some coaxial speakers, I would leave the stock tweeter in to help bring some of that soundstage up from your anxles. You will notice a tremendous difference.
    Are you using the oem head unit?
    If your are looking to use the factory head unit or an aftermarket headunit and don't want to wire amp make sure you get a nice sensitive speaker. Again, I really suggest the bostons. Over the years I have tried many brands and you can't beat Boston acoustics for the money.
  10. Dec 8, 2009 at 5:46 PM
    JBTuncc
    Charlotte, NC
    05 TRD Sport DC 4x4
    I bought the Polk Db651's. I am using the stock h/u. I have considered an amp but don't really want to go that route unless I decide to get a sub.
