Removing the headlight
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman04, Aug 12, 2009.
  1. Aug 12, 2009 at 12:03 PM
    tacomaman04
    tacomaman04 [OP] Well-Known Member
    tx
    prerunner SR5
    volant CAI helix throttle body spacer Westin Black Bull Bar Kc Slimlites130watt long range Black out Taillight Mod Flat Black Rims Flat Black Emblems Two 10' Kenwoods 1200Watt Alpine Amp Surround Black grill Flat Black Front and Rear Bumper
    Anyone know the easiest way to get the headlight out please help
  2. Aug 12, 2009 at 3:15 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    See the attachmnet..... it is not that hard.........:p
  3. Aug 12, 2009 at 3:19 PM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    He's looking for a 1st gen not a second gen.
    I would assume that you take out the top screws on the grill frame in the back, then pop off the filler plate under the headlamp and find a couple screws down there. I don't know for sure, but i gave it a shot.
  4. Aug 12, 2009 at 5:43 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    IF you are just wanting to replace the bulb its self then you just pull that rubber boot off the back that goes into the headlight, then you unplug the wire from the bulb, and there is a metal piece that clips into the light housing remove that piece and the bulb will come out.
    To get the whole headlight assembly off i'm not sure I would guess theres some screws holding it in.
  5. Aug 12, 2009 at 10:40 PM
    Jay W.
    Jay W. Whaaat?
    Jay
    Central, SC
    06 Tacoma DoubleCab SR5 4x4
  6. Aug 13, 2009 at 9:49 AM
    tacomaman04
    tx
    prerunner SR5
    Thanks Jay W. Does anyone know where to get the plastic clips those things are stupid and break to easily... Actually I need all of them haha
  7. Aug 13, 2009 at 12:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Dealer would be the only place to get those clips. Ebay will have them every now and again also.
  8. Aug 13, 2009 at 12:56 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Yes, they're like under $2.00 somethin' for a pair
